![]() | Home > Puma (Tdci) > Puma 2.2 engine code |
Mcd Member Since: 01 Dec 2015 Location: Scotland Posts: 12 ![]() ![]() ![]() |
Hi
Have a puma 2.2 which keeps getting engine fault p0101 how much air needs to leak out of the inter cooler hoses before code is flagged up |
P0101 = Mass Air Flow Sensor
Mass or Volume Air Flow Circuit Range/Performance Problem |
Any ideas what causes this would be much appreciated
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 ![]() ![]() |
There is a hole in one of your intercooler
Hose dude, or not seated properly or a clamp Is not tight its leaking air |
Thanks for that seems to be a slack hose clip on the turbo.
hopefully easy fix as can be expensive
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 ![]() ![]() ![]() |
Excellent news, wish mine was that easy. New Intercooler on its way!
WYL 2015 90 Keeper 2005 R300 Keeper 2019 XC40 Shopping Trolley 2008 110 XS Utility (Friday Build) Gone! |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Have the same , strange noise under load and code P0101. (2.2 puma 2012 and 103.000 km ) Hope to find the leak but with so much under the bonnet, not yet find ! Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Hi,
A cracket hose is the problem ! I did verify all of them , it was the lastone before the throtle . Not a so easy job but happy it will run again. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
