Home > Puma (Tdci) > Puma 2.2 engine code
Mcd
United Kingdom 2012 Defender 90 Puma 2.2 HT Cairns Blue
Hi
Have a puma 2.2 which keeps getting engine fault p0101 how much air needs to leak out of the inter cooler hoses before code is flagged up
Post #478125 1st Dec 2015 8:35pm
dorsetsmith
P0101 = Mass Air Flow Sensor
Mass or Volume Air Flow Circuit Range/Performance Problem
Post #478136 1st Dec 2015 8:50pm
Mcd
Any ideas what causes this would be much appreciated
Post #478141 1st Dec 2015 8:54pm
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
Same Problem
Have a butchers at my Honeymoon over Limp mode thread.
Might give you a couple of pointers!
WYL
PS: Got a perfectly good Air flow Sensor you can try for postage! 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #478159 1st Dec 2015 9:14pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
There is a hole in one of your intercooler
Hose dude, or not seated properly or a clamp
Is not tight its leaking air
Post #478941 3rd Dec 2015 11:48pm
Mcd
Thanks for that seems to be a slack hose clip on the turbo. Thumbs Up
Post #479016 4th Dec 2015 11:30am
dorsetsmith
hopefully easy fix as can be expensive Thumbs Up Thumbs Up
Post #479018 4th Dec 2015 11:42am
Loose hose
Excellent news, wish mine was that easy. New Intercooler on its way!
WYL 2015 90 Keeper
2005 R300 Keeper
Post #479166 4th Dec 2015 7:20pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
First problem !
Hi,
Have the same , strange noise under load and code P0101. (2.2 puma 2012 and 103.000 km )
Hope to find the leak but with so much under the bonnet, not yet find !
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #546431 6th Jul 2016 5:51am
Phil VM2.5
Hi,
A cracket hose is the problem !
I did verify all of them , it was the lastone before the throtle .
Not a so easy job but happy it will run again.
1987 BMW GS80
Post #548617 14th Jul 2016 2:55am
