Home > Maintenance & Modifications > A logical approach to diagnosing a transmission clunk |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
Given that your Defender is an '07 (based on your avatar) the most likely source for your clunk is the rear axle drive flanges, they seem to wear quickest (the '07s seem generally to have better putput adaptor shafts than later models).
To check the drive flanges, jack up one back wheel, remove the wheel (if an alloy is fitted), pop the centre cap off the flange and then rotate the wheel back and forth. If it is worn you will probaby see movement between the shaft and flange. |
12th Jul 2016 10:09am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4225 |
Thanks, I'll look at the rear drive flanges first. If I do see movement, can I just replace the flange, or will the half shaft be damaged too?
12th Jul 2016 11:29am |
Usually both will wear, but if you're lucky the flange will wear faster. All you can really do is inspect both and make a decision based on the result. If you fit a new flange on a worn halfshaft the flange will wear quicker than if you fit it on a new halfshaft.
An alternative would be to replace the halfshafts and flanges with the integrated design used on the very last Defenders. Ashcroft halfshafts and flanges are both cheaper and much better in every respect that the originals, by the way. |
12th Jul 2016 11:50am |
I've just had a quick look at one side, and there is definitely visible movement beyween the shaft and flange. Just need to decide if replacing the flange only or if I'm wasting my money and the shaft should be done too. Quite a difference in price between the two jobs.
Interestingly, the splines are covered in grease, I though they were supposed to be dry. |
12th Jul 2016 6:25pm |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
The best thing you can do is go down to your nearest breakers / scrap yard and remove a pair of discovery or defender 300tdi rear half shafts. These are one piece with integral flange, they never ever wear, and are ten a penny (especially when attached to a disco)
They are a straight swap take all of five minutes to fit and will rid you of axle clunk. I have done this as a matter of course on every late td5/tdci I have owned / come into contact with. |
12th Jul 2016 8:46pm |
Like these?
https://www.ebay.co.uk/itm/131861756991 |
12th Jul 2016 8:57pm |
Yes, perfect.
12th Jul 2016 9:46pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
^^^ Would these shafts fit the 110 "rover" type rear axle?
I see the latest upgrade from LR is one piece 110 shafts, but I wonder if they're stronger than 90/disco/RR type. |
13th Jul 2016 6:57am |
I was also about to double check foment before I buy a pair, I assume they are OK for a 2007 110? Don't 110s have a different axle to a 90? Not sure what a Rover axle is, but maybe I'm asking the same question as diesel_jim.
13th Jul 2016 7:05am |
Sorry, they won't fit 110 I don't think, I wrongly assumed you had a 90
13th Jul 2016 11:31am |
No problem, I really should get round to adding my vehicle details in my signature
13th Jul 2016 11:59am |
I just did a bit of looking through microcat.
I reckon these disco/90 one piece shafts will work on a 110 (not 100% sure about strength though) Reason is; The part numbers for "puma" rear shafts are TOB500020 and TOB500030 and is the same numbers for 90 & 110 & 130. And seeing as the 90 axle is the same (I'm 99.999% sure) on puma's as it is on previous disc braked 90s (and disco/rr, bar the brake disc & calipers) then the one piece shafts and two piece ones should all be interchangeable. However: Seeing the pictures of, and seeing a military Wolf XD 110 the other day, with the "revised" rear shafts, they have a distinct casting mark on the end of the drive flange (maybe this is to show it as a 110 stronger shaft?) so eventhough the 90/disco/RR one piece shafts might physically fit, it doesn't mean that they're up to the job. Maybe the TOB500020/30 shafts are strengthened for the 130 loads, so they become "heavier" duty when fitted to a 110 and "super G wagen spec duty" when nailed into a 90? Or they're only rated for a 90 and will snap like dry straw when in a 130..... |
13th Jul 2016 12:05pm |
Too confusing for me. Think I'll wait till pay day send some money in the direction of Ashcroft.
13th Jul 2016 12:07pm |
Ashcroft list the same half shafts for both 90 and 110 Pumas, so presumably they are dimensionally interchangeable at least.
13th Jul 2016 12:49pm |
