![]() | Home > Puma (Tdci) > 2.2tdci won't start - immobiliser issue? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
If the engine is not started but vehicle unlocked for a short while the immobiliser will arm. So if you see the dash light lighting up you need to press unlock on the plip before starting or it'll start then cut out.
This is the I immobiliser working. If you changed the fob battery I believe it should be done in xxx time period, usually done there and then. Go to the vehicle and press unlock or lock multiple times repetitively until the indicators flash and red dash light flashes very fast for around 10 seconds. That means it's synced and and you should be good to go. There should be no programming needed by a dealer at all. |
Logiedurno Member Since: 13 May 2016 Location: Scotland Posts: 6 ![]() |
Should have maybe mentioned vehicle doesn't have central locking. I never use the alarm function in the vehicle. I tried arming and disarming with the plipper multiple times before and after changing the battery but it didn't turn the alarm on.
The red immobiliser warning light is completely absent from the dash either with or without the ignition turned on. Also got the spare key and plipper that's never been used and tried that - just the same. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Lock four times consecutively then unlock on plip after a battery change.
It'll only respond on the last unlock. Hopefully it's as simple as that. Solved the bowel problem, working on the consonants... |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Logie, I also had a similar problem but after doing some work and disconnecting the battery. Mine happened to be a loose wire in the area of the fuse box. Can't say which as it was found by the mechanic. But worth checking connections perhaps? It was ongoing for a week and was discovered by checking and re checking every connection, every fuse etc. By then we had gone through battery test (full power) changed the fob battery, recalibrated as per agentmulder, so the fuses/connections were the last options. Hope you get it working, bloody nightmare.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
Maybe you are having the same problem I had with water and all the rain
Look here... http://www.defender2.net/forum/topic43089....mmobiliser For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Tried synchronising the alarm plipper- that didn't work. Had a quick check of the fuses and the connections in that general area and can't see anything obviously loose . The vehicle has only done 16k miles from new and not been under water! At this point in time it's off to the main Land Rover dealership in Aberdeen for them to fix. I will post what they find wrong with it for the benefit of anyone else who encounters similar problem. (Along with costs!)
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 ![]() ![]() |
If you access with your EKA code you can use the Defender anyway.
I presume you're gonna get a new ECU. |
I'm no expert- what is an eka code and how and what do i need to access it?
Thanks |
http://www.defender2.net/forum/topic35100.html
Your manual explains the Emergency Key Access code |
Just had a look through the manual and i see what you're talking about. Unfortunately no eka code is recorded in my handbook in the space provided so I'd still have been stuck.
Just going to have to let the dealer sort it out now as the vehicle is with them. Appreciate the advice though- it's something I hadn't heard of before and I will see if the dealer can provide me with the key code. Thanks. |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Can't help ! Had the same problem one day and start again after 10 times . no explanation ! Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
Our 2008 2.4 decided not to start after just being used. It happens now and then but very, very rarely. I just lock/unlock it three or four times and everything in the world is wonderful again. It's a couple of years since it last happened. 1982 88" 2.25 diesel
