Home > Maintenance & Modifications > Interior Mood Lighting
AndrewS
Following the conversion from a 130 DCHCPU to a 130 estate car. I thought that some nice interior lights would be the way forward. Now most modern cars have subtle LEDs or what I have discovered to be called 'mood lighting'. I tracked a company down in Birmingham that makes various types of LEDs.
Following extensive and rigorous trails I have come up with an easy to fit design for a reasonable price.
What it is:- Two x 500mm long x 15mm wide light bars set into a 500mm long 40mm wide holder with a clear cover.
The lights can be set in the manufacturing stage to be switched in various combinations. I have opted for three options 0=off 1=Subtle red 2=full on white (very bright)
Location:- The lights are designed to be hidden from sight behind the plastic trim that is located above the 2nd row doors where the alpine roof window is located (see pic below) the lights shine up onto the roof lining either providing a subtle glow of coloured light or very bright white light.
When the final design is assembled and installed I will post some pictures Thumbs Up
 130's have feeling's as well you know Smile
Post #54490 22nd Jan 2011 9:37am
mse
Be good.
I know VWP do some LED strip lights people have been fitting around where you are thinking - but its more on or...off! Mike
Post #54494 22nd Jan 2011 9:42am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
dam it man don't you ever stop, not that i'm jealous...........much!
nice idea, did you take your insparation from the new vougie thingy?
Post #54501 22nd Jan 2011 10:09am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
That sounds pretty neat. I was looking for a way to increase the interior lighting - I quite like the idea of 2 stage.
Will you just wire it into the existing roof-mounted interior lighting circuit (I assume being LED they don't have much current draw)? If so, where are you positioning your 2-state switch?
Looking forward to seeing the end results. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #54659 23rd Jan 2011 9:10am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Waiting the pics!! Thumbs Up Matteo
Defender 110 Td4 SE MY 09
Post #54716 23rd Jan 2011 8:52pm
Nice idea, there is a lack of light in/around the middle row, but if you are installing lights there, make sure the area is dry, there is an internal drip rail, so you may want to raise the lights 10-20mm.
(Even IF your defender does not leak, the drip rail may also collect condensation)
Post #54764 24th Jan 2011 9:45am
K9F
If they're purchased with a rating of IP65 (IEE 17th Edition Table Rating for those that may wish to refer) water/condensation won't even enter into consideration! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #54775 24th Jan 2011 11:52am
mse
It will be no worse than the other electrical stuff there...just have a quick look at the interior lights Mike
Post #54776 24th Jan 2011 11:55am
AndrewS
Coming along now should have some pictures up tomorrow night. The interior has been upholstered (the sides covered in carpet) 130's have feeling's as well you know Smile
Post #55976 31st Jan 2011 10:56pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
we can supply IP68 30cm flexible LED strips in - warm white, ultra bright white, red or blue
Post #56052 1st Feb 2011 6:03pm
AndrewS
Took these pics earlier in daylight so not perfect conditions to demonstrate the lights.
Rear red ring roof lights.
Post #59281 15th Feb 2011 8:42pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Andrew ...
just took a peek at the photos and saw the red mood light ... made me think about a Submarine at action stations for some reason ..... Cool
Love the concept. we have some LED reading lights for the rear seats when camping that work really well, but this may prove to be a better idea when settng up the waggon with out using the built in lights that have more battery drain.
great stuff! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #59360 16th Feb 2011 12:18pm
mse
wyvern wrote:
Hi Andrew ...
great stuff!
All my STD interior lights already run led light to prevent excessive drain. Mike
Post #59455 16th Feb 2011 8:59pm
dazarooney
I have some LED lights added to mine, I think they look pretty good. LED strip lights
Post #59982 19th Feb 2011 12:32am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
andrew,
why specific red lights?
are alltime on or when the doors open? www.newfoundland.gr
Post #60686 23rd Feb 2011 7:05am
