Home > Maintenance & Modifications > Interior Mood Lighting |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Be good.
I know VWP do some LED strip lights people have been fitting around where you are thinking - but its more on or...off! Mike |
22nd Jan 2011 9:42am |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
dam it man don't you ever stop, not that i'm jealous...........much!
nice idea, did you take your insparation from the new vougie thingy? |
22nd Jan 2011 10:09am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
That sounds pretty neat. I was looking for a way to increase the interior lighting - I quite like the idea of 2 stage.
Will you just wire it into the existing roof-mounted interior lighting circuit (I assume being LED they don't have much current draw)? If so, where are you positioning your 2-state switch? Looking forward to seeing the end results. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
23rd Jan 2011 9:10am |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
Waiting the pics!! Matteo
Defender 110 Td4 SE MY 09 |
23rd Jan 2011 8:52pm |
Nice idea, there is a lack of light in/around the middle row, but if you are installing lights there, make sure the area is dry, there is an internal drip rail, so you may want to raise the lights 10-20mm.
(Even IF your defender does not leak, the drip rail may also collect condensation) |
24th Jan 2011 9:45am |
If they're purchased with a rating of IP65 (IEE 17th Edition Table Rating for those that may wish to refer) water/condensation won't even enter into consideration! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Jan 2011 11:52am |
It will be no worse than the other electrical stuff there...just have a quick look at the interior lights Mike
24th Jan 2011 11:55am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Coming along now should have some pictures up tomorrow night. The interior has been upholstered (the sides covered in carpet) 130's have feeling's as well you know
31st Jan 2011 10:56pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
we can supply IP68 30cm flexible LED strips in - warm white, ultra bright white, red or blue
1st Feb 2011 6:03pm |
Took these pics earlier in daylight so not perfect conditions to demonstrate the lights.
Click image to enlarge Rear red ring roof lights. Click image to enlarge Click image to enlarge 130's have feeling's as well you know |
15th Feb 2011 8:42pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2108 |
Hi Andrew ...
just took a peek at the photos and saw the red mood light ... made me think about a Submarine at action stations for some reason ..... Love the concept. we have some LED reading lights for the rear seats when camping that work really well, but this may prove to be a better idea when settng up the waggon with out using the built in lights that have more battery drain. great stuff! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
16th Feb 2011 12:18pm |
All my STD interior lights already run led light to prevent excessive drain. Mike |
16th Feb 2011 8:59pm |
dazarooney Member Since: 19 Feb 2011 Location: UK Posts: 1 |
I have some LED lights added to mine, I think they look pretty good. LED strip lights
19th Feb 2011 12:32am |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
andrew,
why specific red lights? are alltime on or when the doors open? www.newfoundland.gr |
23rd Feb 2011 7:05am |
