Home > Td5 > Rocker rover bolt tightening
excossack
I am sure in the dim and distant past I have seen a sequence for tightening up the bolts for the rocker cover?...
Can anyone confirm the sequence please?
I think torque is 9nm? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #547046 8th Jul 2016 9:12am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
I didn't think there was a specific sequence, but going opposites would probably be the method? My torque wrench didn't go as low as 9Nm so I just 'nipped' them up. TD5 Defender 90
Discovery 3 HSE
Post #547061 8th Jul 2016 10:51am
dorsetsmith
Re: Rocker rover bolt tightening
i use this
tightening down in sequence a bit at time also make shore the Half moon at the back is in place
Post #547076 8th Jul 2016 11:39am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
There is no sequence per se. Replace it and tighten bolts to 10Nm and use sealant as described in the shop manual (see below). Tighting the bolts gradually from side to side is a good idea...
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #547095 8th Jul 2016 12:32pm
excossack
Maybe I dreamt the sequence or did the same sequence as the head bolts?
Anyway s all done. Tightened in a similar order to above but might of started at one corner and gone zig-zag had tight and then back over and set 10Nm on the torque wrench.
Fingers crossed the leak stops....doubt it though
cheers all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #547118 8th Jul 2016 2:06pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Good practice would be to do it zig zag style.
Same as tightening cylinder head bolts........
Makes sense to me. Smile
Andy
Post #547313 9th Jul 2016 12:07pm
