Home > Puma (Tdci) > smoke from breather hose |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Sump over pressure ventilation is normal until a certain extend. Could you take a pic of the damping (Smoke) and oil residue in engine intake hose (From intercooler to intake manifold)? And what is the car's mileage? Then you'll know whether its on par or to much.
8th Jul 2016 1:59pm |
cannondale Member Since: 26 Dec 2014 Location: carton Posts: 11 |
thx a lot tomorow i will take a pic
8th Jul 2016 2:10pm |
here is video link:https://youtu.be/X4AaLI9hqjY now about 2000km leak 1liter oil ,so much oil in hose |
13th Nov 2016 3:45pm |
That smoke it's normal when engine is warm, try to check when the engine is cold.
But 1 L of oil on 2000km is too much, (mine has 110.000km and do not eat oil) Check the injector copper seal (you need to remove the injectors and renew the copper seals). It is typical for this engine eat oil sucking from the injectors if the seal is/are damaged (oil came from camshaft room). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 25th Nov 2016 7:31am. Edited 1 time in total |
13th Nov 2016 5:17pm |
thx a lot!already fix it,no smoke came out anymore!
24th Nov 2016 10:32am |
IID Pro MV License |
24th Nov 2016 12:06pm |
