Home > Wheels & Tyres > What size are these tyres?
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Thinking of swapping the boosts with 30mm spacers for a set of modulars with BFG ATs. Would anyone be able to say with any degree of certainty what size the tires in this pic i found are likely to be, presumably 16" rims? Thanks.
Post #546833 7th Jul 2016 1:16pm
Green Machine
They're either 265/75/16 or 285/70/16. I would guess 265, which is more typical for 16" rims, but they do look particularly wide in that photo, so could be 285. Hard to tell exactly, but they are most likely to be 265/75/16. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #546834 7th Jul 2016 1:25pm
There's a thread about that...I'll see if I can remember..
https://trektooz.com/the-car/
Post #546843 7th Jul 2016 2:00pm
mata
Awesome, thanks guys. The blog says they're 285/85 but the chassis is on a 1.5" lift.
Post #546846 7th Jul 2016 2:04pm
camelman
I'm running 285's on standard suspension no problem.
Post #546861 7th Jul 2016 3:32pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
if it helps, I'm on 33x12.5x15 on std suspension.
You can frankly fit huge tyres on these things! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #546922 7th Jul 2016 7:59pm
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Wow. Looks awesome. Ordering the same tires. 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #549083 16th Jul 2016 3:27am
mikeh501
the interesting thing about everyones personal views on whether tyres fit or not; is that its so dependent upon what wheels you have, and what you do with the vehicle. for example, the offset could be anywhere between -35 and +8, and somebody who never goes off road will never see the articulation which causes rubbing in the arches and eyebrows; and what about the effect on turning circle!
i know for fact that 265/75/16 on 0 offset modulars only just clear my arches and eyebrows when off road. a 285 would definately rub and negatively effect turning circle. However if i was running them on alloy wheels with negative offset and mostly did road work it would be fine!
Ultmately with all these threads you need more info, and YMMV Thumbs Up
Post #549115 16th Jul 2016 9:07am
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
285's on 0 offset don't rub off road Thumbs Up
Post #549302 17th Jul 2016 1:42pm
mikeh501
I dont doubt you, but this picture is my experience. dont think i would have got a bigger tyre in that arch. having said that people will be making an orderly queue to tell me 285's wont be an issue. I think the other variable is that your average extreme mud tyres are generally bigger than an AT tyre as well.
265-75-16. 0 offset modular. standard suspension
Post #549383 17th Jul 2016 8:52pm
