![]() | Home > Wheels & Tyres > What size are these tyres? |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
They're either 265/75/16 or 285/70/16. I would guess 265, which is more typical for 16" rims, but they do look particularly wide in that photo, so could be 285. Hard to tell exactly, but they are most likely to be 265/75/16. 2005 Td5 | 90 Station Wagon | Tonga Green
There's a thread about that...I'll see if I can remember..
https://trektooz.com/the-car/ |
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 ![]() ![]() ![]() |
Awesome, thanks guys. The blog says they're 285/85 but the chassis is on a 1.5" lift.
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 ![]() ![]() |
I'm running 285's on standard suspension no problem.
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
if it helps, I'm on 33x12.5x15 on std suspension.
You can frankly fit huge tyres on these things! 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 ![]() ![]() ![]() |
Wow. Looks awesome. Ordering the same tires. 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
the interesting thing about everyones personal views on whether tyres fit or not; is that its so dependent upon what wheels you have, and what you do with the vehicle. for example, the offset could be anywhere between -35 and +8, and somebody who never goes off road will never see the articulation which causes rubbing in the arches and eyebrows; and what about the effect on turning circle!
i know for fact that 265/75/16 on 0 offset modulars only just clear my arches and eyebrows when off road. a 285 would definately rub and negatively effect turning circle. However if i was running them on alloy wheels with negative offset and mostly did road work it would be fine! Ultmately with all these threads you need more info, and YMMV ![]() |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 ![]() ![]() ![]() |
285's on 0 offset don't rub off road
I dont doubt you, but this picture is my experience. dont think i would have got a bigger tyre in that arch. having said that people will be making an orderly queue to tell me 285's wont be an issue. I think the other variable is that your average extreme mud tyres are generally bigger than an AT tyre as well.
265-75-16. 0 offset modular. standard suspension ![]() Click image to enlarge |
