![]() | Home > Technical > will TD5 door card fit 09 door |
Will TD5 door card fit door frame from 09 defender ?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Unfortunately not unless it's a post 2004 td5. The welded vs pressed door frame door cards are not interchangeable
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
2003 well it was worth try, back plan A re skin old door
thank |
I think you can get galvanised steel skins now which would obviously help reduce bimetallic corrosion
