Home > Technical > will TD5 door card fit 09 door
dorsetsmith
Will TD5 door card fit door frame from 09 defender ?
Post #546599 6th Jul 2016 5:58pm
grafty99
Unfortunately not unless it's a post 2004 td5. The welded vs pressed door frame door cards are not interchangeable Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #546619 6th Jul 2016 7:17pm
dorsetsmith
2003 well it was worth try, back plan A re skin old door
thank
Post #546621 6th Jul 2016 7:28pm
grafty99
I think you can get galvanised steel skins now which would obviously help reduce bimetallic corrosion Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #546723 6th Jul 2016 10:12pm
dorsetsmith
Driver side door back on with galvanised steel skins and re painted, have passenger side door to do, spotted the 09 passenger door frame on eBay then i remember seeing on the forum that post 05 door frames will not work with older door cards, worth checking be for going ahead with plan B Thumbs Up
Post #546759 7th Jul 2016 7:46am
