Home > Puma (Tdci) > LTB00585 Difficulty Selecting Gears/Poor Gear Shift Quality
Page 2 of 5 <12345>
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Thanks Blackwolf Wink Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #378056 11th Dec 2014 10:07am
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi ,
Anyone tried fixing this.. Slickshift
Post #428337 3rd Jun 2015 2:50pm
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
It's not for a puma 'box. Wink '57 Defender 110 XS Station Wagon 2.4tdci
Post #440607 27th Jul 2015 9:35am
WhathaveIdone!
Russia 2007 Defender 110 Puma 2.4 SW Tonga Green
Took blackwolf's advice to strip down and lubricate the linkages while installing the bushings on my 2007 vehicle. Thre was not too much dirt/debris in the linkages, however the lubricant originally applied had deteriorated into a flaky/powdery material and no longer appeared to have any lubricating qualities.
The pivot ball for the gear shift lever had deep scores or channels worn in it by the plastic cage and the ball was split due to the shaft expanding as it corroded. The corrosion appeared to be due to water sitting in the rubber seal boot that keeps dirt out of the linkage but forms a convenient 'cup'.
I cleaned the ball up with a file and lubricated everything properly and the shift between gears feels unsurprisingly much better, although I haven't driven it since as I am resolving other issues. May look to replace the gear shift mechanism eventually but I'm hoping that it will last for a while as is.
Post #517644 25th Mar 2016 11:40am
Rickydodah
Bought one of these last week, absolute bargain as the whole assembly new is around �100 and it's only this part which wears. It made me realise how good the gear change used to be
http://www.ebay.co.uk/itm/Land-Rover-Defen...2347736643 I started with nothing and still have most of it left!
Post #517710 25th Mar 2016 4:38pm
agentmulder
Kuwait
Did this today.
Haven't heard the 'crick' from 1st to 2nd once over a good drive. Thumbs Up
I didn't need to loosen the forward left bolt (the one that needs the UJ for your socket), I just rotated the whole assembly instead... When you get there you'll know what I mean.
So yeah, these inserts remove a whole lot of potential translational movement, and because there are two they remove rotational movement also.
People who experience no change may be lucky (?) in that their units lined up with the holes already, aaaand the bolts were tight enough for the unit not to go out of place.
Took 2hrs, but I spent a while cleaning things and having a good gander - 1hr is an accurate estimate.
Thanks very much for the images, very helpful! Solved the bowel problem, working on the consonants...
Post #537600 5th Jun 2016 4:53am
ter11
Switzerland 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi All
Anyone else with positive results with fitting these spacers?
If these spacers will improve the crunch noise/feel when shifting 1->2 gear, this would be awesome and I really need to get this fix done.
BR
Ter
Post #546586 6th Jul 2016 5:32pm
Rickydodah
I did this modification some years ago and there was an improvement, not massively but it was still better. Bearing in mind the parts are only a few euros and takes around thirty minutes I found it worth it. Thumbs Up I started with nothing and still have most of it left!
Post #546587 6th Jul 2016 5:54pm
agentmulder
Kuwait
I know it's me again, but it's been a while now....
It really is better!
... for me at least, the fact I had quite a bad instance of the problem initially may play into perceived results. Solved the bowel problem, working on the consonants...
Post #546658 6th Jul 2016 9:18pm
ter11
Thanks!!!
Post #546730 6th Jul 2016 11:35pm
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Hello
Just made this mod on my Defender. For me it turned out that the four Torix bolts holding the gear lever mechanism in place were way too tight and they were crushing the plastic ball joint stopping the spring from allowing the gear lever to spring over to the third gear position. I slackened them off a bit and fiddled with it until I got them just tight enough for the action to work properly. I cleaned and lubed the whole mechanism and added the spacers. I will repost back!
Scrawf
Post #551888 28th Jul 2016 1:59pm
agentmulder
Kuwait
Yeah, IMO it's a bad design from Ford.
By rights it should only be three bolts to hold that bit of plastic that provides the retaining force and friction.
With four one will always be redundant and finding the right balance between a loose feel and the problem you had can be a chore.
Similar reasoning to why tables with four legs often wobble, but those with three are 'self-balancing'.
This stuff is taught to mechanical engineers - indirectly at least... Solved the bowel problem, working on the consonants...
Post #552000 28th Jul 2016 10:04pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
is it two bushes or four bushes mod?
Hi,
Should i only add two spacer bushes (part LR052893) as shown here or is it ok to replace all four with bushes? Cheers. Thanks.
Post #557005 18th Aug 2016 5:17pm
agentmulder
Kuwait
Only need 2.
One locates on the plane, the other determines rotation.
In fact, with more than 2 there is a small chance of them not fitting. Solved the bowel problem, working on the consonants...
Post #557040 18th Aug 2016 7:47pm
agentmulder
Kuwait
Assuming the mount isn't loose as is, you can check if you need/needed them, by looking down the holes as you unfasten to see if they lined up well already. Solved the bowel problem, working on the consonants...
Post #557042 18th Aug 2016 7:50pm
Page 2 of 5 <12345>
