Home > Technical > grinding noise
yanto
Wales
grinding noise
Hi all
My 2003 defender td5 has started to make a grinding noise from the driver side front wheel while on full lock to the left. Any ideas what it is?
Post #546110 4th Jul 2016 10:41pm
agentmulder
Kuwait
My first inclination would be to park it up on full lock to left and have a look underneath. Even better jack both front wheels up and give em a spin...
Dog Solved the bowel problem, working on the consonants...
Post #546124 5th Jul 2016 4:06am
Cupboard
The simplest thing would be the inner edge of the tyre catching the front radius arm, which would be obvious as a shiny wear patch on the arm. Easily fixed by adjusting the lock stop.
Post #546138 5th Jul 2016 6:55am
yanto
Wales
Just had it up on stands and no movement in the bearings. Up or down and side to side. The wheels spin nice with NI grinding or notchy movement. Plenty of room from the steering stops.
The swivel seals need changing for sure. There is some pitting on the swivels.
I have no idea now? Also I live on a bumpy lane and can feel movement through the steering wheel when driving slowly up the lane?
Any suggestions?
Post #546298 5th Jul 2016 6:37pm
agentmulder
Kuwait
ABS? Solved the bowel problem, working on the consonants...
Post #546335 5th Jul 2016 7:43pm
yanto
Wales
2003 defender 90 td5 pick up . No ABS.
Post #546346 5th Jul 2016 8:10pm
dorsetsmith
brake dices stone shield fixing broken
Post #546358 5th Jul 2016 8:37pm
90roy
Universal Joint would be my guess. 300tdi 90 1996.
Post #546837 7th Jul 2016 12:48pm
