![]() | Home > Technical > grinding noise |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
My first inclination would be to park it up on full lock to left and have a look underneath. Even better jack both front wheels up and give em a spin...
The simplest thing would be the inner edge of the tyre catching the front radius arm, which would be obvious as a shiny wear patch on the arm. Easily fixed by adjusting the lock stop.
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
Just had it up on stands and no movement in the bearings. Up or down and side to side. The wheels spin nice with NI grinding or notchy movement. Plenty of room from the steering stops.
The swivel seals need changing for sure. There is some pitting on the swivels. I have no idea now? Also I live on a bumpy lane and can feel movement through the steering wheel when driving slowly up the lane? Any suggestions? |
ABS? Solved the bowel problem, working on the consonants...
2003 defender 90 td5 pick up . No ABS.
brake dices stone shield fixing broken
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 ![]() ![]() |
Universal Joint would be my guess. 300tdi 90 1996.
