Home > Technical > Which seal and how can I check? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Bonsoir a tous,
Bit of oil showing under the hub cap and spraying the rear right wheel. Only been a couple of days, as it was clear of oil/spray when I cleaned the Def over the weekend. Not done more than 50kms in that time either, so hopefully not too much oil lost (if it's from the Diff). But I'm not sure whether this is a drive shaft seal failure or hub seal failure? Can anyone tell from the photos and give me an idea of what to check to be sure? Help much appreciated as ever. If anyone wants to offer advice and give Blackwolf a break as he's become my personal mechanic's mate recently, I am sure he'd appreciate it!! Hub cap on: Click image to enlarge Cap off: Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
5th Jul 2016 5:22pm |
17
FTC5268 - ВНУТРЕННИЙ (SEAL-STUB AXLE INNER) |
5th Jul 2016 6:38pm |
Click image to enlarge |
5th Jul 2016 6:41pm |
Many thanks, great diagram. Easy job? Anything else worth doing at the same time. Perhaps a diff oil change? Monsieur Le Grenadier
5th Jul 2016 7:10pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Errrr ...is not that drive member dust-cap split? Steve.
5th Jul 2016 7:12pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
what HOG said, was about to post but he beat me to it 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
5th Jul 2016 7:14pm |
Yes. Does that mean anything or is it just an observation and something else that needs to be ordered? No influence on the leaking oil? Monsieur Le Grenadier
5th Jul 2016 7:32pm |
Hi Grenadier the oil/grease you see on the wheel will be coming from the split in the dust cap. It weeps out between the splines of the drive flange and shaft, you can clearly see the oil/grease around the end of the shaft in your last image. At under £1 for a cap it's a cheap and easy fix to try instead of pulling your axle apart 2014 110 2.2TDCi XS Station wagon
5th Jul 2016 7:37pm |
Wow. That much egress through the split? Is that normal? Monsieur Le Grenadier
5th Jul 2016 7:45pm |
^^What he said. Easy to spot and equally easy and cheap to fix. Steve.
5th Jul 2016 7:46pm |
