Home > Puma (Tdci) > Oil filter help. Urgent!
Bluest
I've just dropped the oil out of my 2007 2.4. Removed the old oil filter and gone to fit the new one.
The old one, Purflux I think, was a snug fit on the spigot inside the filter lid and sort of clicks in and out nicely. The new one, a Mann is pretty loose once I click it in. Doesn't feel right. It can move from side to side a bit, rather than staying centred, like the bore is a bit too big. Anyone any experience of this?
I've got the correct part I think, Mann HU 711/51x but don't want to put it in if its wrong.
I guess I could put the old one back in if this new one isn't right. Help!
Post #546278 5th Jul 2016 5:41pm
gilarion
That is definitely the right part number fits both the 2.4 and 2.2.
These are the measurements of the filter
The spigot centre hole, both top and bottom should measure 29 mm
The diameter of the filter 64 mm
The height of the filter 69 mm
Man say it fits 2.4 from MY05/7 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #546281 5th Jul 2016 5:54pm
Bluest
Ok, I dug the vernier calipers, remembered how to read them and did some measuring.
All the dims are as you say above on the new filter. But the old filter is different in one measurement, ithas a 25mm, not 29mm, bore. It's the old filter that's fits nicely and new one is loose. Am confused Confused
Post #546291 5th Jul 2016 6:21pm
Bluest
Can anyone recall when they have fitted a filter into the screw on lid does it sit snugly in the middle or can it be moved side to side?
Post #546308 5th Jul 2016 6:51pm
Bluest
The filter I have taken out is Purflux l358a, which has a 24mm bore, but is a cross reference with the Mann but that has a 29mm bore?????
Any help would be appreciated. I think I might need to declare the car off the road until I can get a genuine Land Rover filter.
Post #546325 5th Jul 2016 7:23pm
driver9
The bore of a genuine filter (LR030778) is 22.5mm
Post #546329 5th Jul 2016 7:37pm
Bluest
Which is even smaller than the Purflux one I took out.....
Post #546344 5th Jul 2016 8:02pm
Bluest
Going to get a proper genuine filter tomorrow, don't want take a risk with something that doesn't seem right.
There's a photo here with the Mann on the left and Purflux on the right. It's not that clear but I think you can see that the bores are noticeably different
Post #546363 5th Jul 2016 8:42pm
williamthedog
I've used bearmach filters and haven't had any problems with them.
They fit quite snug as far as I can remember.
Post #546430 6th Jul 2016 5:34am
Bluest
Bought a Ford one today, Fitted snug like the Purflux one. Will avoid the Mann one in future.
Post #546726 6th Jul 2016 10:27pm
