![]() | Home > Maintenance & Modifications > posi-locks |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Are these ok for the defender wires http://www.posi-lock.com/index.html
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
NO! NO NO NO NO NO!!!!
(Rant over) No, there rubbish! Well not rubbish but they wont last, nothing like that ever does. Just solder and heat shrink and it wont fail any time in the future. If you want something easy to join the wires try these In-line solder splice at the bottom of the page. http://www.vehicle-wiring-products.eu/VWP-...lterms.php Pete. |
well i have one of the internal external temp guages like DGs that needs to be wired to lights etc i wont some leds in the back some time
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Inside I would be ok with a 'Quick splice connector' or 'ScotchBlock'. But I wouldn't use one where it is open to the element. I have had these fitted in vehicles for over 5-10 years without them failing. But as above, if you can solder them and then heat shrink it is the best option..... My pet hate is crimps... they really don't work!
Glyn ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
IMHO solder and heat shrink tube is the only way to guarantee a good solid connection
barjout Member Since: 09 Dec 2010 Location: Ottawa Canada Posts: 16 ![]() ![]() ![]() |
+1 ![]() |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Ditto- it's the ONLY way to do it right 'first time only time' D300 HSE 110 |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Adhesive heat shrink tubing adds mechanical strength
http://www.power-store.com/?id=61 |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Just twist them together and hope, AKA Land Rover Style
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Forget twisting just wrap them together with tape ![]() ![]() Serious Scotch blocks work ok (even though some people will tell you they are evil)! Soldering or using "normal" connectors Mike |
