Home > In Car Electronics > Issue with Heated Rear Window and Headlamp |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
The most simple thing to check would be for an earth issue Mike
18th Jun 2016 11:51am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Welcome to D2net. Strange issue you have there. Not heard of thet one before.
Is it really the headlamps that have become "connected" to the HRW, or is it the sidelights? If it is the sidelights, the most obvious place to look is the heater rear window switch, as they are connected through the switch illumination. Pull it out and check the connector, and for any signs of having got too hot. As mse says, a bad earth is the most common cause of stuff like this. Anything been modified on the vehicle recently? 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
18th Jun 2016 12:32pm |
pugracer Member Since: 18 Jun 2016 Location: NT Posts: 4 |
Thanks guys!
You are right, it is the sidelights actually. Let me look into the HRW switch. The car hasn't done any mod recently. I have light bar put on a while ago with illuminated switches installed above the console. Maybe that's related too? |
19th Jun 2016 2:24am |
Somehow the problem fixed itself before I could find a time to trace the wires!
5th Jul 2016 1:52am |
