Home > Td5 > More suspension and spring questions TD5 2001 90
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Sorry, more suspension questions. I think I know what brands I'm going for in this department but as I will only be using main road and motorway and not towing, what spring weight should I be looking for, for a fairly comfortable ride? They can be seen listed as light, medium or heavy duty.
I want to keep the ride height standard but the better Britpart springs (yellow) are rated as heavy duty.
Bilstein shocks are probably what I'll be getting.
Thanks in advance Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #545654 3rd Jul 2016 2:38pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
I would stick with the std landrover springs for your requirements Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #546056 4th Jul 2016 8:47pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Use the seach feature there a few good threads about the smoothest spring set up. If you are not off roading you can really comfy up a 90. I recall something about RRC springs in a 90 making it quite comfortable (nit sure but check it out). 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #546119 5th Jul 2016 12:27am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
If you don't want to 'stiffen' it up, If you don't want to lift it up, and it you dont want to change It's ride height ... then the advice from johnszs is the best you'll get - leave springs as standard and just replace shocks Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #546196 5th Jul 2016 11:56am
