Home > Puma (Tdci) > Upgraded turbo manifold gasket and studs?
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
During our rally through France and Spain this last week, I managed to blow the gasket between the exhaust manifold and turbo.
As I'm running as much power as I think I can get from the 2.4, I think it's probably sensible to upgrade this gasket and the studs to stop it from happening again.
Is there an upgrade kit out there or am I going to have to make a copper one myself?
Post #545669 3rd Jul 2016 4:48pm
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
Hi Mate, there is: https://www.nakatanenga.de/fahrzeugtechnik...turbolader
However if your upgrade the gasket in in order not to blow it, there is a big chance you will just move the result to a different location like warping your manifold. So my advise would be to install an EGT sensor and ease up a little on the throttle. Its still a Transit engine, no matter how much power you squeeze out. I'm pushing 200bhp out of my 2.4
Post #545844 4th Jul 2016 7:33am
leeds
Available in the UK from 4x4overlander.
I do not know of any upgraded studs.
If you have squeezed maximum power out of your engine, it might be worth considering backing the power available off a little bit.
Who's remap are you using? What other upgrades have you done?
An EGT might be worth considering. Madman EGT available from 4x4overlander as well
Brendan
Post #545876 4th Jul 2016 9:32am
N16kct
Ordered from Brendan and now fitted thank you!
One of the studs had sheered but not completely, a tiny part of it was still connected!
Also my old gasket... Well, no words needed...
Post #547810 11th Jul 2016 3:20pm
