Home > Puma (Tdci) > Upgraded turbo manifold gasket and studs? |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Hi Mate, there is: https://www.nakatanenga.de/fahrzeugtechnik...turbolader
However if your upgrade the gasket in in order not to blow it, there is a big chance you will just move the result to a different location like warping your manifold. So my advise would be to install an EGT sensor and ease up a little on the throttle. Its still a Transit engine, no matter how much power you squeeze out. I'm pushing 200bhp out of my 2.4 |
4th Jul 2016 7:33am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8579 |
Available in the UK from 4x4overlander.
I do not know of any upgraded studs. If you have squeezed maximum power out of your engine, it might be worth considering backing the power available off a little bit. Who's remap are you using? What other upgrades have you done? An EGT might be worth considering. Madman EGT available from 4x4overlander as well Brendan |
4th Jul 2016 9:32am |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 |
Ordered from Brendan and now fitted thank you!
One of the studs had sheered but not completely, a tiny part of it was still connected! Also my old gasket... Well, no words needed... [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Jul 2016 3:20pm |
