10AS grey connector block
I am working on a neat modification and I need to remove the grey connector from the 10AS unit, any ideas what needs to be pushed, pulled or squeezed to enable the plug to be removed ...
Push and hold the central plastic pin and pull....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
22nd Jan 2011 9:07pm
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
