Home > Maintenance & Modifications > Front Door captive nuts - Land Rover, Bearmach or ??
Page 1 of 3 123>
Andrew*Debbie
One of the captive nuts on our 2011 Hard top is stripped. Any suggestions on which ones to get?
I can get genuine Land Rover ones, Bearmach or something else.
The genuine ones are £4.92. Bearmach is about £3.92 I only need one, but will probalby go ahead and replace two since I have take the hinge off anyway. I don't care about saving a pound. Just want the better part.
The 110 came with this bodge job on the front doors. Water gets in through the gaps on either side of the spacer. The door is misaligned too.
I've replaced the bodge with Nakatanega stainless bolts, but the top one just spins.
Post #543517 26th Jun 2016 12:37pm
Retroanaconda
I'd use Land Rover ones, but the Bearmach ones will probably be OK.
The gasket between the hinge and bulkhead pillar and spacers between the hinge and door are both factory. The latter adjusts the in/out position of the door to get it flush with the bulkhead pillar.
Post #543519 26th Jun 2016 12:40pm
Andrew*Debbie
Sounds good. Genuine Parts on order.
I think I'll give the £0.36 Britpart ones a miss. I like doors that stay on.
Post #543521 26th Jun 2016 12:46pm
Andrew*Debbie
Maybe Genuine LR are not the best ones.
A quick search found the part number for the nuts.
WA138480, superseded by BYH500100.
Rimmer Bros. says BYH500100 no longer available, use LR055527. Genuine Land Rover part.
This is the photo they have for the part:
This is what arrived today:
I wonder if these were used in production? Could be some 2.2Puma owners will be in for a surprise when it is time to replace the door hinges.
These are going to be harder to use. Still not sure exactly how I'm going to get them in place. Maybe I can use one of the door bolts to hold the plate. Unbolt the hinge from the door side too, put the one bolt through and then unscrew my "handle" bolt. Might be able to use a magnetic tool.
On the plus side, these should last longer than the old style captive not.
Anyone used these ??? I could use a suggestion or two. Should I send them back and get the Bearmach parts.
Post #544172 28th Jun 2016 12:41pm
Those are the nut plates for the second row doors on a 110 or 130 SW, USW, or DC. They won't help you at all for the front doors.
You need (I think) ASR1459
Post #544195 28th Jun 2016 2:20pm
Andrew*Debbie
Thanks!
I'll have to send them back to Rimmer Brothers.
Ugh.
Post #544198 28th Jun 2016 2:24pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Got to love this forum Bow down
Post #544206 28th Jun 2016 2:46pm
Andrew*Debbie
Yup.
Just sent an email to Rimmer Bros. customer service. Fingers crossed the return will be painless.
Post #544207 28th Jun 2016 2:48pm
Andrew*Debbie
So did I.
ASR1459 is superseded by BYH500100 on most vendor's websites. On Rimmer Bros. Genuine LR BYH5000100 is no longer available and they say to use that 2nd row door nut plate.
ASR1459 (BYH500100) - CAPTIVE NUT DOOR HINGE DEF WA138480> - See more at: http://www.brit-car.co.uk/product.php/8226...FpFKA.dpuf
Post #544209 28th Jun 2016 2:58pm
Lotus_esprit_s1
Rimmer Bros are actually correct with their part numbers - the last few months of defender production went back to the captive nut plates LR055527 for the front bulkhead.
Post #544382 29th Jun 2016 6:15am
Martin
Site Admin
But the question remains, how do you fit the second row nut plate to the bulkhead.
There's no access from the back!
BYH500100 seem to be available from (literally) everywhere else except Rimmer  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #544390 29th Jun 2016 6:52am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #544396 29th Jun 2016 7:23am
Andrew*Debbie
At some time in the future a few people are going to be in for a surprise.
I should see if I can manage to fit the part. With some corrosion protection, the nut plates should last a very long time. I've got a couple of magnetic parts grabbers that might work. Maybe.
Or I can try ordering the Bearmach parts. I probably should anyway as a backup.
Post #544405 29th Jun 2016 8:11am
Andrew*Debbie
epictrail wrote:
https://www.lrdirect.com/BYH500100-Nut-Flanged/?keep_https=yes
Brand: LAND ROVER
Part Number: BYH500100.L8
Price:
£18.13 £21.76 inc VAT (EU only)
Quality: Original Part from Land Rover UK
Warranty: 1 YEAR WARRANTY
Availability: SUBJECT TO LR STOCK + 1 DAY
YIKES!!
Brand: BEARMACH
Part Number: BYH500100.M8
Price:
£0.46 £0.55 inc VAT (EU only)
Quality: LRD Workshop Approved
Availability: TO ORDER + 1 DAY
I'll get some of those incase I can't make the nut plate work.
Post #544407 29th Jun 2016 8:14am
You may well find that the price quoted for the genuine is for a UOM greater than 1, whilst the Bearmach price is for a single one.
Quite often if it is a small part, LR supply (for example) packs of 10, and the redistributor price lists from places like LRDirect and Brit-Car don't seem to identify this.
Alternatively it may simply be a huge rip-off!
Post #544409 29th Jun 2016 8:18am
Page 1 of 3 123>
