Home > Maintenance & Modifications > Drain plug key sizes
Bluest
Can anyone confirm what size drain plug keys I need to change the axles and transfer case oil on a 2007 Puma? I already know I need a t50 torx for the gearbox.
Post #544361 28th Jun 2016 10:35pm
lohr500
A standard 1/2" drive ratchet works a treat. (Well it worked fine on my later 2012 Puma, but I don't think the earlier ones are any different).
For the Transfer box fill plug, which is also 1/2" square drive, I found it easier to use a 1/2" to 3/8" adaptor, then a 3/8" extension and 3/8 ratchet to get a bit more clearance around the handbrake drum.
Post #544370 29th Jun 2016 5:21am
miker
1/2" square drive.
Extension and / or universal joint handy for the transfer case
Post #544415 29th Jun 2016 8:38am
Bluest
Cheers all, I've got a fairly big selection of 1/2" drive ratchets, extensions etc so I guess a specific drain plug won't be needed.
Post #544429 29th Jun 2016 9:21am
