![]() | Home > Maintenance & Modifications > Drain plug key sizes |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1331 ![]() ![]() ![]() |
A standard 1/2" drive ratchet works a treat. (Well it worked fine on my later 2012 Puma, but I don't think the earlier ones are any different).
For the Transfer box fill plug, which is also 1/2" square drive, I found it easier to use a 1/2" to 3/8" adaptor, then a 3/8" extension and 3/8 ratchet to get a bit more clearance around the handbrake drum. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
1/2" square drive.
Extension and / or universal joint handy for the transfer case |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4241 ![]() ![]() ![]() |
Cheers all, I've got a fairly big selection of 1/2" drive ratchets, extensions etc so I guess a specific drain plug won't be needed.
