Home > Td5 > G Force Oil |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Any good?
http://www.ebay.co.uk/itm/172122201158 1999 Td5 110 CSW 1961 Series 2 88 LPG |
27th Jun 2016 10:11pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I'm using it in my 200Tdi and she hasn't complained.
6k oil services so its only in there a 3 months so probably not long enough to be an issue but I'm happy with it Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
28th Jun 2016 11:58am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1600 |
nope it should be 5-30 fully synthetic to the correct spec.
28th Jun 2016 5:33pm |
go direct
www.opieoils.co.uk |
28th Jun 2016 6:23pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
recently had some issues with an oil brand at work that I wont name on here but has a high evaporation rate and results in too much oil mist entering the closed circuit breather system, carbonising the turbo and intercooler etc. I would always suggest using a premium brand of the correct grade and spec DEFENDER 90 TDCI XS,
28th Jun 2016 6:32pm |
Thanks for the advice. I'm used to much cruder LR engines which will take any old lube. 1999 Td5 110 CSW
28th Jun 2016 7:55pm |
yes older engines are generally less fussy but the emissions kit creates all sorts of extra considerations DEFENDER 90 TDCI XS,
28th Jun 2016 7:59pm |
