Home > Puma (Tdci) > Brakes |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I would suggest clamping off the rubber brake lines front and back (to isolate front/back calipers/cylinders). is still not working correctly then the problem is master cyl end. If ok remove a clamp and pump pedal to check that part of system.. and so on.
Use proper brake hose clamps not mole grips. 1953 80" 1987 mini city e 2011 90" |
26th Jun 2016 8:17pm |
Daz Member Since: 10 Aug 2014 Location: west yorks Posts: 46 |
Thanks Mr James for input , Replaced master cylinder and bleed through using easy bleed and unfortunately there's no result the pedal fells exactly the same . Does anyone think it could be a servo issue ..Cheers Daz .
28th Jun 2016 4:38pm |
