Home > In Car Electronics > Wiring question
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
Wiring question
Hi everyone,
First of all apologies if this has been covered to the nth degree, but a good search on the forum didn't really bring anything up specific.
I bought a single din stereo today in preparation for my audio install, and decided to have my first rummage around my new defender. It's a 12 plate 90 in farmer spec and as such has never had a stereo or speakers fitted to it. So I removed the speaker grille on the drivers side first and found two wires unused just behind it, one black and red, one black and pink, so I presumed, great this is the drivers side sorted. I then proceeded to take the passenger side off only to find a lack of any sort of looms at all. After this I thought I'll have a look behind the dash to see what was stashed behind there, I found a little bundle with the aerial, and iso connectors in there. I could see there were two corresponding wires on one of the iso connectors which matched the drivers side wires. So my question is, does anyone have any idea where the passenger side might be hiding, or is this something I would have to wire in myself? And also if I wanted to also wire in some tweeters, how would I go about this? The head unit is a pioneer and has 3 RCA's?
Once again apologies for the probably very simple questions, but I'm a trimmer by trade so have no trouble pulling stuff apart, but when it comes to car electrics I get sweaty palms! Embarassed
Cheers,
Lew
Post #543377 25th Jun 2016 7:24pm
dorsetsmith
wrong information posted see below 07 -12 radio wiring read your post on my phone and miss your reg date no wonder you confused Whistle
Post #543382 25th Jun 2016 8:00pm
Lew-M
Ah okay thanks, so there should be the wires for the lh speaker stashed somewhere with one black/yellow one black/orange. Thanks!
Lew
Post #543386 25th Jun 2016 8:11pm
Lew-M
Hi there again,
Quick question if I can, I had a root around in the dash to locate my speaker wires and am now left a little confused, the only loose wire I can find has two wires running to it coloured black/white and black/brown. These match up with the other two wires in the back of the iso block. However unlike the drivers side which is split into two separate connectors this is a single black connector. Also you can see from the pics that the drivers side contains two connectors and 4 wires whilst the passenger is just one connector of two wires?
Iso block with 4 wires
Drivers side connections
Passenger side?
Anyone any ideas on this?
Cheers,
Lew
Post #544461 29th Jun 2016 12:17pm
Martin
Site Admin
See this thread, identical question:
http://www.defender2.net/forum/topic40776....eaker+loom
The three pin plug is not it Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #544479 29th Jun 2016 12:47pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Looks to me like it's wired for a very basic Mono radio (is there such a thing ??)
The ISO block is only wired for one speaker and a supply, the connectors on the second picture are certainly the same type as for a speaker, odd that they have two wires in each one though, that's suggesting there's provision for a second speaker somewhere.
The connector shown on the last picture is not for a speaker or anything else to do with a radio, I don't know what else though.
Post #544483 29th Jun 2016 12:54pm
Lew-M
Haha thanks, I just found them, I can testify that they are indeed taped in the most awkward spot land rover could find I'm sure. One very sore hand later I managed to free them up, interesting that the black connector seems to be provision for a tweeter, makes life a bit easier when I come to put them in!
Thanks for your help,
Lew
Post #544488 29th Jun 2016 1:07pm
Martin
Site Admin
Yes the 3 pin connector is for the dash-top tweeters. There will be one the other side too.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #544489 29th Jun 2016 1:08pm
2007 > 2012.
Post #544497 29th Jun 2016 1:19pm
dorsetsmith
try this will be more helpful
Post #544573 29th Jun 2016 4:45pm
Lew-M
Thanks that makes a lot more sense!
Post #544582 29th Jun 2016 5:22pm
dorsetsmith
https://1drv.ms/b/s!AtZSoWFHDgnGhDbxYedTopmyd1rA manage to transfer it to one drive
Post #544600 29th Jun 2016 6:13pm
Lew-M
Thanks very much Thumbs Up
Post #544632 29th Jun 2016 8:04pm
