Home > Maintenance & Modifications > Wing top vent screws |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
number 8 x 1 code AB608088
http://www.defendergeek.co.uk/screw---ab608088-19914-p.asp |
25th Jun 2016 5:08pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
Thanks, so size 8 x 1"? 1999 Defender TD5 110
25th Jun 2016 5:20pm |
/\/\yes that right!
25th Jun 2016 6:07pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 717 |
Buy some security type ones while your at it. Plenty on ebay. Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
25th Jun 2016 9:10pm |
Is there a specific thread ? 1999 Defender TD5 110
26th Jun 2016 7:30am |
Hi i only have a metric gauge so the screw diameter is m4(equates to n 8 screw as it is usually double) and the pitch 1.5 I you can get them from here: http://www.a2stainless.co.uk/Land-Rover-De...AKMGW.aspx
and they accomodate cplate! |
26th Jun 2016 8:45am |
Thanks I will have a look at A2 stainless
cheers 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
26th Jun 2016 12:30pm |
Screws ordered from A2. Excellent service - Sent an message via ebay on Sunday, a few replies later all sorted.
Vent fitted today. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Jun 2016 4:37pm |
bhjvdb Member Since: 07 Sep 2016 Location: Chesire Posts: 1 |
Hi there,
Only just joined the community here. I have a 2007 TD5 Hard top (90) County. Starting to do some small cosmetic changes to it, and running into some small obstacles along the way. I bought one of these side vents: http://www.ebay.co.uk/itm/322050903785 However, after prying off the original plastic one (and the old pins breaking off in the holes), I realised the holes in the vent do not match the "bigger" screw holes. It does however match the holes of the pins which I can push out, but I do not know what size screw and grommet I need to get. The screw is a lot smaller than the original, but the head size needs to be the same so it holds the vent in place and does not slip through the hole. Help please! Thanks |
7th Sep 2016 7:39pm |
