Home > Maintenance & Modifications > Adjusting the handbrake cable
Motoberg
I've just replaced the handbrake cable and after a week or so, it needs a bit more tension
(its now not tight enough to pull the handbrake down when its off and the handbrake warning light stays on )
Is there an easier way to adjust it rather than unbolting the handbrake lever ?
There doesn't seem to be an easily removable panel above it ( next to the drivers seat )
Its a TD5 110 CSW
Post #542974 24th Jun 2016 11:08am
Access from underneath or via the panel in the centre of the seatbox.
Post #542981 24th Jun 2016 11:40am
