Home > Maintenance & Modifications > Which Anti-Seize to use
Page 2 of 2 <12
ericvv
nitram17 wrote:
I have used the Weicon and ive heard the swiss are so tough the they spread it on toasted baggette for their breakfast!
Yes. but that they do on the other side of the Röstigraben. Laughing
https://en.wikipedia.org/wiki/R%C3%B6stigraben
Thumbs Up Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #542624 23rd Jun 2016 4:39am
nakatanenga
Germany
After using the BERNER or identical paste for over 15 years and we never had any issues with galvanic corrosion, i would say it is more than just anti-seize.
couple of months ago i have met the car in which one of our first SS-bolt kits was fitted about 12 years ago. NO sign of corrosion! WANTED:
SII or SIII in max 1.5k
Post #542625 23rd Jun 2016 5:37am
Andrew*Debbie
Re: Which Anti-Seize to use
Riccarton wrote:
Could you elaborate on this please? Reasoning & outcomes would be useful.
Many thanks Thumbs Up
Sure,
It is in the references in the original post.
Quote:
Copper base anti-seize offers good corrosion protection on all kinds of steel, but not stainless steel. Copper on stainless steel creates an inter-crystaline corrosion, which can make actual stainless steel parts crack and break. This is why the nuclear power plants do not allow copper with any material which comes in contact with the stainless steel parts.
http://depacproducts.net/anti.html
To be fair, Depac make a metal free anti-seize.
Molyslip make Copaslip, but recommend their nickel based product for stainless:
http://www.molyslip.co.uk/media/upload/fil...t-(V2).pdf
Loctite make several copper based products and they are not recommended for stainless steel.
It is in the applications details chart in the middle of this pdf:
http://hybris.cms.henkel.com/medias/sys_ma...333918.pdf
Post #542631 23rd Jun 2016 6:56am
Andrew*Debbie
Laughing I'll stick to Vegimite.
Weicon AS contains nickel and is both toxic and a carcinogen. Weicon High-Tech is not as nasty. I still wouldn't eat it.
I really should get a tub of the High-Tech or similar. They are fine for all applications except extreme high temperatures and much better for our health.
Post #542632 23rd Jun 2016 7:03am
nitram17
Peter your personal insight and anacdotal experience of use of the berner paste probably points to the fact that any barrier paste even lithium grease or vasaline of honey for that matter may do to prevent galvanic corrosion if it keeps the moisture out ........but others experience or use may be different to yours and i would prefer to buy and use stuff that states on the tin that its designet to be anti seize and anti galvanic corrosion paste.............if you look a tthe berner data sheet it states it has not been tested for conductive properties so on that basis i am out..........I know you stick that paste in with your ss bolt kits and you have many years using it and that fine and dandy but many others on here will state that they have also used copaslip for years on their defender bolts and nuts (SS ans well) and have had no corrosion but i would personally prefer not to use copaslip as the idea of shoving a copper based grease between ss and ali just feels wrong!
Post #542635 23rd Jun 2016 7:28am
Andrew*Debbie
Normfest BMP == Bremsenmontagepaste which translates to brake assembly paste.
The English language catalog says it is copper paste. Page 13 of the first reference.
Quote:
This gold-coloured copper paste facilitates as- sembly and is resistant to alkalis and acids.
It is an all-purpose grease for assembly, screw fit- ting and lubrication tasks.
- Heat resistant up to 1,100°C
The German data sheet says it is a blend of soft metals and is silver coloured.
Quote:
Zudem basirt die Paste auf einem Mineralö mit Weichmetallen als Festschmierstoffe.
Quote:
Technische Daten
Inhalt : 250 g
Spezifisches Gewicht (bei 15￿C): 1,1 g/Kubikzentimeter
Farbe: silber
Feststoffgehalt: 40%
Penetration: 240 bis 265 1/10mm IP 50 / 88 Konsistenz (N.L.G.I.-Klasse): 2 bis 3 DIN 51 818 Reibkoeffizient (20°C): 0,11 SRV Test
Schweißlast: 3100N VKA Test
Flammpunkt: +200°C ISO 1523
Hitzebeständigkeit: +1100°C
Reference:
http://www.normfest.de/fileadmin/user_uplo...enance.pdf
https://www.normfest-shop.com/_cms_/docume...on--de.pdf
Post #542679 23rd Jun 2016 10:40am
Andrew*Debbie
Nakatanenga say both Berner and Normfest BMP work and I'm not going to question their experience.
Unless Nakatanenga say otherwise, I'm going to use Weicon AS since I already have it.
Post #542683 23rd Jun 2016 10:50am
nakatanenga
Germany
You mention "personal insight and anacdotal experience" as negative, and "a copper based grease between ss and ali just feels wrong" as positive.
Ok, your point of view.....
The Normfest is silver colour, not golden.
Normfest is the producer, Berner (like Würth) a large distributor with own brand.
We never tried Weicon but we have personal insight and anacdotal experience from some customers that it was doing no harm to their nuts......
.....and bolts. WANTED:
Post #542693 23rd Jun 2016 11:22am
Andrew*Debbie
If is it silver, it should be fine (copper free)
The english catalog is probably a translation error. (Translator was given the wrong text or some such)
Post #542694 23rd Jun 2016 11:27am
leeds
Taken from Berner
[quote]
details
Application areas
Assembly aid for the risk of corrosion, temperature and environment-loaded components such as screws or flanged
Main User
building construction
and civil engineering
Heating technology
Metal and
maintenance workshops
Product advantages
high-performance lubricant and protective agent based on aluminum
Well suited for use in extreme temperature ranges
immediate lubricating effect
High pressure loading
reduces fuel consumption by thin-film lubrication
Properties
of heavy metals and mineral oil-free, protects against corrosion, resistant to water, alkalis, salt water and acids.
Not electrically conductive.
Post #542697 23rd Jun 2016 11:31am
nakatanenga
Germany
Just phoned Berner and they confirmed that the Berner stuff is made by Normfest. WANTED:
Post #542700 23rd Jun 2016 11:36am
Andrew*Debbie
Good to know. Thank you for the investigation.
Post #542703 23rd Jun 2016 11:55am
Page 2 of 2 <12
