Home > Technical > Ratchet Jack
stanley
Ratchet Jack
Back in the winter at about 4 am in the wet and ice I had a puncture , it was a bit of a pig to get the bottle jack in the right position a fading torch and lying on my front ,
Thinking ahead and as I'm off to Billng next month , just wondered if anyone with far greater knowledge than me can think of a reason that the old style ratchet jack wouldn't work on a 61 plate USW ?
Just thought it might have been easier in that situation to use
Thanks
Greg
Post #542304 22nd Jun 2016 8:46am
If you mean the earlier type of LR jack (the tall screw thing that fitted the holes in the ends of the chassis) then I'm sure it would work but it was a ghastly thing, hard work and really not very safe. I replaced mine with a bottle jack for ordinary use very early on.
I always carry one of those cheapo blue tarpaulins so if I have to change a wheel I don't have to grovel about on a wet or muddy road.
A Hilift is easier and quicker to use than the LR pillar jack, and no less safe.
I still have the pillar jack abomination somewhere if you really want one.
Post #542335 22nd Jun 2016 10:29am
Cupboard
Was it really that bad?!
Post #542374 22nd Jun 2016 11:59am
stanley
Narrow road, pitch black . Trying to get jack in right position meant laying into the road further than I liked , just thinking in certain situations maybe a bit safer at front and back of car. did have triangle out and florid coat on but still felt a bit vulnerable
Post #542376 22nd Jun 2016 12:06pm
Fatboy Slim
Wales
Honestly, I'd rather do that than use the Censored old ratchet things that should have been banned years ago. They have a habit of damaging tdci rear cross members as well.
Post #542380 22nd Jun 2016 12:14pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Just drive slowly another 100yds to a safer spot. The tyre should be fine if you don't go far.
Post #542417 22nd Jun 2016 1:47pm
miker
I'm in agreement with Fatboy, can't stand that ratchet thing. Mine is lifted slightly as well, so it can only just get a wheel off the ground on perfectly level surface, and it's pretty hairy.
Slow as hell too, even when using a drill to turn it Laughing
I'm going to get a bottle jack. Far more secure.
In terms of access it's pretty easy to get it in the right spot from front, rear or side I think.
Post #542451 22nd Jun 2016 3:32pm
YOLO110
Australia
Slight thread drift...
I have a 1.5 Ton capacity trolley jack... is that man enough to lift one corner of a 90 under the axle jacking point on level ground in order to change a tyre? YOLO... You Only Live Once...
Post #542470 22nd Jun 2016 4:57pm
Yes.
Post #542471 22nd Jun 2016 4:58pm
YOLO110
Australia
Perfect! Thumbs Up
Much easier to use than the OEM bottle jack. Smile YOLO... You Only Live Once...
Post #542472 22nd Jun 2016 5:00pm
I Like Old Skool
Can you explain to me where the axle jacking points are on a Defender? AFAIK there aren't any and the jack should only be placed under the axle tube, not under any of the suspension brackets.......
Post #542480 22nd Jun 2016 5:11pm
YOLO110
Australia
That is my understanding too... Question YOLO... You Only Live Once...
Post #542484 22nd Jun 2016 5:14pm
You won't do any harm at all with a trolley jack if you locate the jack underneath the attachment point of radius arm to axle.
Post #542499 22nd Jun 2016 6:20pm
I Like Old Skool
I figured you probably knew this but I just wanted to clear up any misconception. Far to many don't understand the difference and half of them seem to work at Kwik Fit (the other half work at Halfords where they pretend to fix bicycles, but that is another topic! Rolling Eyes ).
It probably won't do any harm to jack a land rover under the axle brackets because they are pretty beefy fabrications. This doesn't make it right and that Kwik Sh!t attitude that the jack can be stuck just anywhere could do some serious and possibly dangerous damage to most normal cars (look how flimsy some of the pressed steel wishbones are on many independent suspension cars to get an idea of what I am talking about).
Jacking under the radius arm brackets means jacking under the radius arms and this in turn means you are jacking the vehicle using the front radius arm bushes. Again, probably not a big issue if the bushes are in good shape but why do this when it is no more trouble to use best practice and get it right?
Post #542658 23rd Jun 2016 8:18am
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
I've just chucked out the screw-type pillar jack in my DCPU and put in the later type/SW bottle jack kit in the battery box, since I've fitted +2" dampers and dislocation cones so my wheel will still be on the floor with the screw jack at full extension!
Also means I can use it to lift my trailer if I have a flat on that instead of carrying two jacks. Sounds like you just need a decent torch Whistle Laughing Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #543181 24th Jun 2016 10:20pm
