Home > Technical > Door loom |
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Jun 2016 5:21am |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Oh yes - the dreaded rubber tube. Home of "The Broken Wire"
22nd Jun 2016 5:49am |
Click image to enlarge |
22nd Jun 2016 7:24am |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
I just used some braided sleeving I had and whipped a bit of heat shrink on both end. The beauty about this, is I can stretch the braid and see inside for damage TD5 Defender 90
Discovery 3 HSE |
22nd Jun 2016 8:30am |
That sounds like a much better solution. You'll be forever chasing wiring problems otherwise
22nd Jun 2016 11:58am |
I don't have a picture of it in it's finished state, but you get the idea here. I might even have some spare if you want, i'll dig it out and pop it in an envelope if you like?!?
TD5 Defender 90 Discovery 3 HSE |
22nd Jun 2016 12:49pm |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Cheers guys. Thanks Huffhuff, that'd be great, very kind of you. I'll pm you my address.
22nd Jun 2016 9:41pm |
