![]() | Home > Maintenance & Modifications > Powerbleed |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5062 ![]() ![]() ![]() |
How does it work? Mike
Didnt Toyah sing that? 130's have feeling's as well you know
Whos Toyah
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
It pulls the brake/clutch fluid through the pipes from the bleed nipple using a vacume (spelling ??) pump system, i find you get the best results if you hold the pistons in the calipers right back. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Cool so makes the job one man then?! Mike
urr yes but its handy to have someone tipping fresh in the top as it dont half gobble the fluid up If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
