Home > Group Buys > Nanocom Evolution Group Buy
Sign Up
(11)
(0)
(1)
User Registered Confirmed
geobloke14th Jun 2016 7:41pm
Waldo19th Jun 2016 7:58am
gtmotorsport30th Jun 2016 12:54pm
dorsetsmith21st Jul 2016 2:42pm
Leaky 11021st Jul 2016 3:12pm
sirrus21st Jul 2016 3:14pm
df125th Jul 2016 6:47pm
vulcanfreak27th Jul 2016 7:31am
Hufflepuff27th Jul 2016 9:36pm
West Yorkshire Lofty29th Jul 2016 8:36am
Telshe30th Jul 2016 5:20pm
huffhuff14th Jun 2016 12:45pm
Page 1 of 9 123456789>
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
NANOCOM EVOLUTION GROUP BUY
Hi all,
I’m thinking about running a Group Buy on the Nanocom unit from Blackbox Solutions (a forum sponsor). This post is really a ‘run it up the flagpole’ type affair to start with, mainly to gauge interest levels and to determine if it will be viable (worth it). Discounts are available on kits, accessory items, additional cables and licences (but does not include remap for Discovery 3 TDV6)
I’ll focus on the TD5 and Puma, but the deal will also include units for Discovery II (TD5, Motronic VCool, P38 (GEMS, EDC, Motronic) and CAN BUS Freelander, Disco 3 and 4, RR Sport 05 - 09, RR Sport 10 - 13 and RR L322 10 - 13.
I’m sure I don’t need to go over the benefits of this unit, but some main points are highlighted below (clicking the hyperlinks will take you to current documentation with full explanation). For a full breakdown of what it can (or can’t) do, have a look at their website http://www.nanocom-diagnostics.com or feel free to ask here and i’ll try and answer (if I can’t, i’ll happily contact BBS and ask on your behalf).
Defender TD5
- TD5 Engine Management System
- TD5 Map a flashing function to remap the programmable type ECU's. Full of functions and features, the TD5 engine management software offers reading and clearing of fault codes, the read and write of certain settings including Injector codes. Viewing of Live data, checking of Outputs and putting the ECU into learn mode for the security coding. You should note that there are 2 variations of the TD5 ECU, MSB denotes a non programmable version where the later NNN can be programmed using the Nanocom Evolution.
- Wabco ABS system (up to 2010) Functions include Read and Clear faults, View Inputs and check various Outputs on the ECU and you can also use the Nanocom Evolution to bleed the primary and secondary hydraulic circuits.
- Lucas 10AS Alarm (up to 2010)
 The 10AS alarm will read and clear triggered events, allow you to view various settings and data as well as make and save changes to the data.You have a choice of Inputs again to see live data and can also test certain outputs to make sure the alarm is working as it should. Finally you can also program the PLIP/Fob (not the key) to the ECU.
Puma 2.4 & 2.2
- Puma 2.4 & 2.2 Engine Management and Instrument Pack
The functionality of the Puma Defender engine management and Instrument pack is quite limited in what is actually available to read and change but we are working to add flashing of software to these ECUs. Functions include reading and clearing of faults, changing of settings such as Speed limit (not removal), Fuel tank volume and Tyre size are available. You also have the option to view Inputs which is live data being transmitted from the ECUs.
- Wabco ABS system (up to 2010) Functions include Read and Clear faults, viewing Inputs and the check of some Outputs on the ECU. You can also use the Nanocom Evolution to bleed the primary and secondary hydraulic circuits.
- Lucas 10AS Alarm (up to 2010) The 10AS alarm will read and clear triggered events, allow you to view various settings and data as well as make and save changes to the data.You have a choice of Inputs again to see live data and can also test certain outputs to make sure the alarm is working as it should. Finally you can also program the PLIP/Fob (not the key) to the ECU.
Discounts
1 - 4 kits = no discount
5 - 9 kits = 5% discount
10 - 14 kits = 10% discount
15 - 19 kits = 15% discount
20+ kits = 20% discount
Further savings can be made by paying in their base currency (which is the Euro) and by using an app/bank which gives true interbank exchange rates and no currency conversions fees. I’ll go into this further if the post looks positive. Don't forget, as a forum sponsor, a 10% discount is already there for the taking. This means we'll need to get interest in up to 15 kits
Process
- Interest gauged (sign up) until July 31st 2016
- If successful, i’ll contact BBS with details (I will need what you want to buy, your full name and email address via PM)
- I give you a special discount code and you purchase through their website (no money comes my way, you pay them direct)
- They post out by DHL and usually arrives within a couple of days. I’ll double check, but this isn’t UK only. They will post to Europe and Worldwide
As always, there are other alternatives on the market which may, or may not be better. You can do your own research on this - but the nanocom does seem to be overwhelming accepted as the best of breed unit in the Defender community. More than happy for thoughtful, helpful and constructive posts, queries and suggestions. We are all grown up, so no blatant anti-BBS diatribe please.
I do not work for these guys, just very happy with their product and use it on my TD5 (and soon my discovery 3). I get nothing out of this other than the same discount as offered. I do the leg-work, you get the discount. I’m genuinely just nice like that Smile
The one caveat is the offer will only be open to members of the forum with a joining date prior to this post (to stop people signing up just for the discount).
If i've missed anything or you have any questions, please leave a message here or PM me.
Ta
Ben TD5 Defender 90
Discovery 3 HSE
Post #540033 14th Jun 2016 12:41pm
geobloke
Hi Ben. Count me in for a TD5 defender kit.
Post #540147 14th Jun 2016 7:44pm
huffhuff
Will do Smile TD5 Defender 90
Discovery 3 HSE
Post #540173 14th Jun 2016 8:37pm
huffhuff
Just to add, i'm going to run the same group buy on the Disco3 forum. If you are on both, please only sign up to one of the threads. This is to open it up to the wider community and hopefully boost interest Smile TD5 Defender 90
Discovery 3 HSE
Post #541437 19th Jun 2016 10:11am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I would be interested in a Puma 2.4. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #541439 19th Jun 2016 10:42am
huffhuff
Super duper @swollock. If you could click the button at the top it will help in keeping everything together and then messaging should it all go to plan.
Cheers Smile TD5 Defender 90
Discovery 3 HSE
Post #541448 19th Jun 2016 11:06am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hi Ben, Thought it was worth mentioning I purchased a Nanocom Evo via the LZ group buy you ran last year, it arrived promptly and with all the extras specified so thank you very much for sorting it all out Very Happy
I'd like to add the Discovery 4 unlock pack code NCOM54 and also the screen suction mount NCOM30 please? I presume I'd also need the Canbus lead NCOM24 to connect up to the D4 or does it come with the unlock kit?
Harry
Post #541735 20th Jun 2016 10:21am
gtmotorsport
United Kingdom 2006 Defender 110 Td5 CSW Zermatt Silver
Very interested in a Defender TD5 package if this group buy has sufficient interest to go ahead.
Post #544433 29th Jun 2016 10:36am
huffhuff
Hi guys, obviously the saving won't be quite so good as before Brexit. But there is still a saving to be made and a bit more if you pay in euros.
You can also use a banking app on your smartphone, which gives true interbank rates and no currency transfer fees. Last time I bought something, paying with the free app actually saved an extra £51ish in various fees and exchange rates.
I can PM anybody interested with details of the app. It's actually really good to use if you travel lots. You pre-load it with money and exchange to the right currency free and at great rates. You then don't have to use your credit or debit card. It's a mastercard so comes with full backup and security etc.. You can have a 'digital card' and they post a physical master card too. TD5 Defender 90
Discovery 3 HSE
Post #547823 11th Jul 2016 4:07pm
Leaky 110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Just joined the forum and noticed this post. I'm in the market for a nanocom or similar, if this is still a goer id be happy to make up the numbers.
Post #548218 12th Jul 2016 7:39pm
Charles
Luxembourg 2015 Defender 110 Puma 2.2 SW Barolo Black
Hi
I actually have a Faultmate msv2 with Disco 3 license from my previouse car.
What do you think?
Is it better to change the license on the faultmate to a Puma 2,2 or to sell the faultmate and going for a nanocom evolution?
Best Regards Very Happy
Charles
Post #549089 16th Jul 2016 5:47am
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
Hi Ben
Count me in for one.
Telshe
Post #550085 20th Jul 2016 9:06pm
daingeanrob
Ireland 2003 Defender 110 Td5 HT Oslo Blue
count me in for one for a defender td5 03
Post #550220 21st Jul 2016 2:34pm
dorsetsmith
cont my in for TD5 kit
Post #550224 21st Jul 2016 2:45pm
Martin
Site Admin
Click the sign up button guys (available on the full not mobile site at the moment)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #550231 21st Jul 2016 3:28pm
