Home > Td5 > TD5 Intercooler |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Shouldn't need to flush it but if you do something like brake cleaner will do 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
16th Jun 2016 11:38am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Wash some methylated spirits through it to remove any oil it will show up any leaks very quickly.
Then drain it out and leave it in the sun for a good hour to make sure it has all evaporated and is dry inside. Do not put it back on wet or with vapor inside it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
16th Jun 2016 11:50am |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 353 |
Could I use IPA (isopropanol) as I have lots of it and no meths!
16th Jun 2016 7:23pm |
Yup as shaggy dog says really.
Don't be shy with the gunk and water, really soak the cooler to remove as much grime as possible. If you want to speed the drying process up you can stick a hair dryer in one port and let it pass hot air through the cooler, dries it real quick. |
16th Jun 2016 7:26pm |
