![]() | Home > Puma (Tdci) > Engine surging when changing gears |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
First test is to unplug the clutch switch and see if that makes a difference, No difference and you've found the problem.
dulwich man Member Since: 29 Nov 2011 Location: Dulwich Posts: 64 ![]() ![]() ![]() |
Are your bake lights working? sounds daft but if the brake fuse has blown it thinks it is in low range with associated changes to the way it is fueled.
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 ![]() ![]() |
Yes brake lights working
Clutch switch seems likely as I have an aftermarket cruise control fitted that should be wired to the clutch but when clutch dipped it doesn't disengage cruise so will try that first |
Gets worse with clutch switch disconnected so guess we have a winner! Didn't look very closely at the switch, does it have any adjustment in it as it feels like it is just in the edge of catching at the bottom of the clutch pedal
