Home > Technical > Discovery 2 Steering Box on a Defender
nickhodgson
Will it fit? If I change the drop arm? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #536023 31st May 2016 5:28am
mikeh501
interesting one. is the disco2 steering box fit the same way as the def?
i just fitted a new steering box to my project, and changed over to a discovery 1 drop arm and steering rod.
Post #536250 31st May 2016 6:57pm
Fatboy Slim
Wales
Will have a look but I'm 99% certain it won't fit.
Post #536283 31st May 2016 7:55pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Pretty certain they don't fit too, but it does beg the question. Any reason why?
Post #536326 31st May 2016 9:28pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
I did it a 10+ years ago on a D2 axled 90 project.
Basically it can't be done easily.
The mounting bolt spacing is different in the vertical plane which results in the lower set of holes being below the chassis rail, and the input shaft spline diameter is smaller on the d2 box.
I got around this by buying a new D2 steering column UJ section and a Defender one and making one out of the two.
I dont think it was worth it at all really. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #539984 14th Jun 2016 7:13am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Oh, I just bought "land rover discovery defender 4 bolt steering box" on eBay and hope to change it for my loose/leaky one. I have a TD5. Will this not work then?
Sad TD5 Defender 90
Discovery 3 HSE
Post #540002 14th Jun 2016 8:21am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
That should be fine, the Discovery uses the same steering box as a Defender, the Discovery 2 uses a different box. http://www.yorkshireoffroadclub.net/
Post #540007 14th Jun 2016 8:43am
huffhuff
Phew, cheers Wink TD5 Defender 90
Discovery 3 HSE
Post #540019 14th Jun 2016 9:29am
