Home > Technical > Discovery 2 Steering Box on a Defender |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
interesting one. is the disco2 steering box fit the same way as the def?
i just fitted a new steering box to my project, and changed over to a discovery 1 drop arm and steering rod. |
31st May 2016 6:57pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Will have a look but I'm 99% certain it won't fit.
31st May 2016 7:55pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Pretty certain they don't fit too, but it does beg the question. Any reason why?
31st May 2016 9:28pm |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
I did it a 10+ years ago on a D2 axled 90 project.
Basically it can't be done easily. The mounting bolt spacing is different in the vertical plane which results in the lower set of holes being below the chassis rail, and the input shaft spline diameter is smaller on the d2 box. I got around this by buying a new D2 steering column UJ section and a Defender one and making one out of the two. I dont think it was worth it at all really. 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
14th Jun 2016 7:13am |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Oh, I just bought "land rover discovery defender 4 bolt steering box" on eBay and hope to change it for my loose/leaky one. I have a TD5. Will this not work then?
TD5 Defender 90 Discovery 3 HSE |
14th Jun 2016 8:21am |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
That should be fine, the Discovery uses the same steering box as a Defender, the Discovery 2 uses a different box. http://www.yorkshireoffroadclub.net/
14th Jun 2016 8:43am |
Phew, cheers TD5 Defender 90
Discovery 3 HSE |
14th Jun 2016 9:29am |
