Home > Technical > No main or dipped beam |
cutts Member Since: 06 May 2016 Location: UK Posts: 36 |
Click image to enlarge |
11th Jun 2016 5:51pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Quite possible it is in the stalk switch as it's the known weak link( this why some folk fitt a headlamp loom with seperate relays).
If you know how you could join then wires at the switch plug to prove its faulty. Double check the headlamp relay in the cabin fuse box is OK before ordering parts. It supplies power to the switch when the ignition is turned on. Cheers. Cheers, Kyle. |
11th Jun 2016 6:23pm |
I've already ordered one, be alright the end bit spins around anyway.
Thanks for the advice I'll give it a try tomorrow bypassing it. Quite a few forum previous posts say about towing putting extra extra strain on the switches.. Well this landie has barely drove without towing (152,000) |
11th Jun 2016 11:14pm |
Going to try it now as I wrote my car off this morning so really need to get it sorted asap
swapped rear heater relay for the lights relay,swapped dim dip relay for another still no difference have ordered stalk. |
12th Jun 2016 1:01pm |
