Home > Technical > No main or dipped beam
cutts
2008 Defender 110 Puma 2.2 HT Alveston Red
Just picked up a defender, side light and light was out
Changed bulbs
Side lights and dimmed beams work on bottom stalk
On the top stalk only the flash and dipped beam works for 10 seconds
Am I right in saying top stalk
Post #539433 11th Jun 2016 5:47pm
cutts
Post #539435 11th Jun 2016 5:51pm
Alien
Australia
Quite possible it is in the stalk switch as it's the known weak link( this why some folk fitt a headlamp loom with seperate relays).
If you know how you could join then wires at the switch plug to prove its faulty.
Double check the headlamp relay in the cabin fuse box is OK before ordering parts.
It supplies power to the switch when the ignition is turned on.
Cheers. Cheers,
Kyle.
Post #539441 11th Jun 2016 6:23pm
cutts
I've already ordered one, be alright the end bit spins around anyway.
Thanks for the advice I'll give it a try tomorrow bypassing it.
Quite a few forum previous posts say about towing putting extra extra strain on the switches.. Well this landie has barely drove without towing (152,000)
Post #539504 11th Jun 2016 11:14pm
cutts
Going to try it now as I wrote my car off this morning so really need to get it sorted asap
swapped rear heater relay for the lights relay,swapped dim dip relay for another still no difference
have ordered stalk.
Post #539608 12th Jun 2016 1:01pm
