Home > Technical > Wheel overhaul -bearing/swivel/shafts/brakes & a catch22 |
WhathaveIdone! Member Since: 04 Feb 2016 Location: Sakhalin Island Posts: 27 |
I have a similar age vehicle that also had a rough life before. The rear drive flanges on mine were pretty far gone, so I just pulled apart the rear axle - the result that the car is off the road at the moment while I wait for driveshafts, stub axles and brake spares to arrive. I probably could have put it back together and operated it in the meantime, but chose to use the time to strip down and repaint the calipers and do some other stuff that was outstanding. I also wasn't happy with the condition of the rear brakes which had a jammed caliper and the retainer rings and wiper seals hanging on the piston.
I have to attack the front axle as well and I am not sure that there is really a 'best' approach. Seems to be a choice between inspecting a little at a time in the hope that you can put it back together with minimal spares or buying everything and just going for it. Probably not very helpful, but at least you know you're not alone...... |
6th Jun 2016 9:28am |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 |
I have done the exact same job on my 2008 non abs 110 recently.
My advice is to order everything new in one go. My front drive flanges where rust welded to the shafts as yours and where an absolute to get off. In fact I knackered the top swivel bearings doing so. There is a good chance you will do the same with yours. The discs (rotors) on mine werent to bad, neither were the wheel bearings but I changed them all because I didnt want to have it all apart again. |
6th Jun 2016 12:06pm |
Nice to know I'm not alone indeed!
Where did you source your parts? As kits? 'OEM' ? Next task is to actually make sure I get everything Solved the bowel problem, working on the consonants... |
6th Jun 2016 5:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
My approach is to buy all the parts I might need, and if I don't use them I have them in stock for next time. The downside is cost and storage space, but when you need a part urgently or it's Christmas day or similar you'll be glad.
I pity my poor old relatives when I snuff it and they have to clear out my stuff, though! |
6th Jun 2016 6:33pm |
Good call. I can understand the logic.
Part of me a screaming 'it's a 2008 for eff's sake!', feel like I've bought into a restoration project Nice feeling when you take it out after a successful home workshop session though. I'd pay a lot more for my vehicle now... ugh... already did! Solved the bowel problem, working on the consonants... |
6th Jun 2016 7:22pm |
I got everything from here http://www.shop4autoparts.net/Defender I rang them and they were very helpful, I didnt want the kits full of Chinese parts sold in some places. No connection BTW. They do kits and use some OEM parts in them. I asked for Timken or SKF bearings which they provided. Other bits that I ordered that are often forgotten were new stub axle nuts (peen over type for Pumas), oil seals, thread lock, caliper bolts and gasket sealant. Download and print an exploded drawing of the swivel and tick off everything you need. |
6th Jun 2016 9:04pm |
Looks like I've found some blokes with experience.
I'll write up a shopping and to-do list and post it here for a sanity check. See if there is anything missing re. required tools also. Thanks chaps, top work Solved the bowel problem, working on the consonants... |
6th Jun 2016 9:14pm |
