Home > Puma (Tdci) > Alarm and Door locks
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Any wizards on who can help with alarm system and an immobilised puma.(MY2007).
My drivers door actuator was playing up so gave a good squirt of lubricant and it seemed ok then yesterday it all went petong.
The doors will not lock with the fob, the drivers door will lock with the key but does not trigger the other doors to lock.
The internal lights do not come on when the door is open although they will if switched on.
I checked and cleaned all the door switches, I also found Fuse7 had blown, but as soon as I replace it the sounder starts. Elderly neighbours not amused.
I checked the rear off side door and it had a break in the wiring to the actuator. It had obviously happened before as it had enough joints to make a hippy happy. Replaced the wire soldered and heat shrunk so no more a possible problem.
I have taken out the actuator from the drivers door and was looking to find some detail on the internals.
It has a 12v dc motor and a micro switch. Tested the switch and it seems ok. The gears that drive the plunger are a bit iffy but cannot get them out of the casing to confirm.
Any tips? Tommy
110 XS TDCi
Post #537143 3rd Jun 2016 9:28am
dorsetsmith
FUD500020 LR part number drivers door attractor
attractor driver wiring is in parallel to each unit (black arrows ) the 12v is supplied by swapping + and - over to make it mover up and down
switch work between the other two wires orange arrows
test it off the land rover if attractor will not drive up and down when power is supplied to it new one is needed
Post #537158 3rd Jun 2016 10:28am
Coolcamper55
Thanks for that, have studied the wiring diagrams but no further insight gained. The diagram sows the wiring from the switch and the motor. I tested the motor on the bench, works fine, switch already tested.
I think it might be the gearing in the unit. It seems to have a clutch mechanism but its a bit too loose from my pov. Tommy
110 XS TDCi
Post #537173 3rd Jun 2016 11:08am
dorsetsmith
i had one apart that stopped work and find teeth missing from the gears
Post #537175 3rd Jun 2016 11:16am
Coolcamper55
How did you get the gears out?
I seem unable to get the shafts out Tommy
110 XS TDCi
Post #537178 3rd Jun 2016 11:21am
dorsetsmith
small hammer and old screw driver not going too be used again Whistle
like lot of parts not to be serviceable Crying or Very sad
Post #537183 3rd Jun 2016 11:28am
Coolcamper55
Drilled a hole in the side to allow the shaft to be punched through. As suspected the clutch mechanism has failed. New one from dealers tomorrow hope this fixes the problem.
BTW the dealers price £36 was good when you consider no delivery charges and others were £33 plus delivery of 4 days.
Thanks ever so much for your assistance and prompt response. Tommy
110 XS TDCi
Post #537211 3rd Jun 2016 12:26pm
Coolcamper55
Picked up the part from dealers, £27 +vat. Fitted and then hard reset of alarm and all back to normal. Tommy
110 XS TDCi
Post #537475 4th Jun 2016 2:07pm
