![]() | Home > Puma (Tdci) > Help! Loss of power despite fixed injector copper gasket |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20671 ![]() ![]() |
Did you have any injectors replaced? If so was the learn process completed?
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
No, they weren't replaced, just put back in.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
Did they / and are you supposed to replace the retaining bolts too?
I think they did replace them.
(Caterham, congrats! Post #4000 is coming up!) |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 ![]() ![]() ![]() |
Sounds like a faulty injector mate, so did the first issue for that matter. Have injectors tested, and have a look at the VCV valve, those are problem causers as well.
Btw injector retaining bolts MUST be replaced when taken out. And have the injector seats been properly cleaned before they where put back in? Fiddling with a commonrail fuel system seems easy but only the smallest cockup can have major consequences. |
Bad news
![]() The garage where they repaired the gasket issue is very knowledgable (independent Defender specialist), so I presume they did everything properly on the gasket change. Albeit I have to concede you're probably right that having a faulty injector might be the next conclusion. How bad of a repair is fitting a new injector? What baffles me is why for a single trip after the copper gasket repair everything seemed fine. If the injector was faulty all along, it should have still caused trouble. How could it be? |
Replacing the injector is fairly easy, pretty much the same as what was already done, only with a new one instead of the old one.
Important though is to go through the injector learning procedure again. Little surprised though that the specialist did not decide to have the injectors tested anyway, now they have to come out again so you washed the 7 quit per copper washer down the drain. New injectors are insanely expensive though, I recently went with Denso reconditioned (reconditioned by Denso) which I am very happy with, still insanely expensive but quite a bit less than newnew. Can't think of any explanation of why the issue was gone after the washer change. |
Wa hoo !
4000. Hadn't noticed. ![]() how sure are we that it's the injector? To my find there's no end of things that can cause what seems like injector knock and presumably a loss of power. Can anyone confirm if doing an injector re-learn should show up if an injector was actually faulty? good luck. |
Can be many many things causing the issue but you gotta start somewhere and a leaking or dripping injector could definitely cause it.
Only way to see if these injectors are faulty is to take them out, get them to a Bosch Diesel Center and have them tested. When doing tie relearn procedure other things happen, to sum up: - Injector code programming: programs the unique injector codes to the ECM, these codes resemble individual injector tolerances, these things work with insanely small tolerances which makes every difference count - Pilot correction relearn, this lets the car idle through different RPM's teaching the car to compensate the normal wear and tear. This will not help anything if an injector is faulty. |
E.D. while your at it, you loosing coolant or oil by any chance? And is the coolant still clean clear pink? Blue smoke on startup? These Puma engine's are tough as hell, but when an issue occur's finding it can be a major undertaking.
No smoke when starting up. It smoked somewhat blueish before the copper washers were replaced, but that's alleviated.
What I noticed is a faint wisp of vapour rising from the oil filling opening, when I take the lid of just after stopping the hot engine. |
Ok, blue smoke would be a good indication of of a heavily leaking injector as thats what unburned looks like from the exhaust.
Stuff coming from oil filler is normal, just hot oil and some splatter from the camshafts. I would start by having the injectors tested, replace VCV valve, make sure the injector seats in the engine are properly clean before refitting and follow the correct procedure reprogramming them. While your at a diesel specialist for the injectors anyway, couldn't hurt having a compression test done either, would rule out valve stem seals and piston rings. |
Thanks, tomdaprince,
I think this will be the best course of action. Just have to decide now whether to go to my Landy specialist or directly to a Bosch service, the latter is many miles closer. Compression test is also a very good idea. Thanks a lot everyone for chiming in and your good advice! E.D. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Hate to say it but that sounds exactly like our 2.4s when we have cracked pistons.
