Home > Technical > hockey sticks and trailing arms |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
No I don't think they are the same, or at least there are different types. The difference is with the width of them rather than length or anything else. They might be interchangeable as long as you have the correct bushes.
No doubt someone with more knowledge will be along soon to provide the detail of what parts can be swapped between models. But is not then you need to be on the safe side of getting the right part numbers for your year/model to be sure. |
31st May 2016 7:43am |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Could be all the same, on Defender a narrow type was used up to 1994 and the wide one from 1994 (300tdi), Difference would be in hockey stick to axle, have a quick peak to see if you see any differences, if not you can just interchange them.
All Disco 1's used the wide (new) type. Hope you have a hydraulic press as changing them could be interesting without one. |
31st May 2016 8:45am |
