Home > Maintenance & Modifications > Rear Door rattle !!!!
Wheel
Hi Gents,
I wonder if anyone can help as the rear door on my year old 90 rattles and annoys the f*@k out of me.
I've adjustable the striker a couple of times but to no great avil, is there a knack or something i'm missing.
It's in for a service next week but if poss i'd like to try sorting it before getting them to do it.
Thanks,
Mark
Post #533650 22nd May 2016 9:16am
miker
Often the weight of the rear wheel bounding around causes it. Check that there is no damage/stress fractures around the wheel mounts or frame of the door.
Post #533656 22nd May 2016 9:38am
Wheel
Thanks Mike,
I'll check but i'm hoping not as it's not a year old yet !!!
Mark
Post #533663 22nd May 2016 10:01am
Fatboy Slim
Wales
Change your hinges Thumbs Up
Post #533668 22nd May 2016 10:39am
Happyoldgit
Mark around the striker plate in pencil, slacken the fastenings and move it in toward the front of the vehicle a bit, tighten the fixings and test / repeat as required. Unless you spend all day opening and closing the door at a year old the hinges shouldn't have worn that much. Steve.
http://forums.lr4x4.com
Post #533939 23rd May 2016 10:17am
clifflandy
United Kingdom 2007 Defender 90 Puma 2.4 HT Zambezi Silver
I agree it's very unlikely a one year old will be needing new hinges.
In addition to moving the striker plate it's also possible to adjust the rubber contact on the striker plate. This worked for me and stopped my Puma rear safari door rattle. With the door open locate the two screws on top of the striker plate rubber. Unscrew a little and you will notice the rubber contact will drop slightly. This means the door will be gripped more tightly when closed. After this it's a matter of trial and error picking an adjustment which holds the closed door tightly enough to prevent a rattle.
Post #533944 23rd May 2016 10:31am
Wheel
Thanks Steve + Cliff,
I have actually adjusted it every which way but I started by moving it further fwd as that was my first thought.
It didn't really make much, if any difference but I was looking at it yesterday and thought of making a shim/spacer for the rubber block although as Cliff pointed out it may just release a bit if undone so i'll try that later.
Thanks,
Mark
Post #533947 23rd May 2016 10:40am
Defender2014
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi,
Not sure if it was my imagination or wishful thinking but I felt fitting the nakydakydoodaa gas strut kit to mine helped with the rattle........ Defender Puma 110XS SW
Kawasaki ZX9R El
Suzuki RGV250M
Honda CB250N Super Dream
Post #534699 25th May 2016 9:13pm
agentmulder
Kuwait
I've had creaking too, continued with wheel on and also off ... lots of driving either way.
Chucked in a fair amount of white lithium and worked the hinges while I was installing stainless bolts = creak gone.
A heavier wheel installed (wolf with MT) - still no creak.
Lube worked for me at least.
Result = I am hearing the next creak down the list, which appears to be interior trim creaking when the vehicle flexes (110)
I've started talking to myself Whistle Solved the bowel problem, working on the consonants...
Post #534708 25th May 2016 9:26pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I stopped mine by adjusting the external spare wheel carrier. It's a mantel style one and a few of the bolts had worked loose and gave the worst rattle in the world 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #534719 25th May 2016 9:49pm
cozz
I stopped mine by adjusting the external spare wheel carrier. It's a mantek style one and a few of the bolts had worked loose and gave the worst rattle in the world
I did mine tonight, spare off, nuts were loose, now sorted
Post #534723 25th May 2016 9:53pm
NMBRPL8
Australia
Touch wood, but none of my 30 year old vehicles that have done 100s of thousands of km over remote aussie dirt roads have displayed any problems from having the spare on the back except requiring repair and reinforcement of the rear door's steel frame.
Post #534800 26th May 2016 9:24am
Wheel
Sorry Gents I need to apologise as I omitted an important fact, I have 18" Overfinch wheels with 265/75 tyres fitted.
For scientific reasons, we'll not quite, it was off for its first service I fitted the original Boosts with 238/85 MTR's (don't ask) and adjustable the latch and low + behold no rattle but now i'm not sure if it's the adjustment or weight of wheel + tyre so i'm gonna weigh them to see if there's a lot of difference and will feedback findings.
I must say I'd forget and was pleasantly suprised how well it drove and how much lighter the steering was with the original set up on.
Unfortunately the black Overfinch wheels just look so much better and will be going back on very shortly !!!
Mark
Post #535798 30th May 2016 9:20am
Cupboard
Surely 18" wheels with tyres should be lighter than 16" wheels? Isn't that the whole point?
Post #535832 30th May 2016 11:45am
