Home > Technical > Puma cutting out |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Best to post this in the Puma section, but is the fuel poor quality/dirty?
Chris. |
17th Jan 2011 1:16pm |
Plumber Boy Member Since: 04 Apr 2009 Location: Hertfordshire Posts: 21 |
Hi..Shorti26
Yer iv had the same agro with my last 2 Ford Transits...which share the same basic engine type.! My last one did it really badly..i was without it many times whilst in under warrantly.!! It had new fuel pump and an ECU upgrade in the end, which cured it..it did it worse when cold. On my latest Transit..which has done 28,000 miles and 3 years old, its doing the cuting-out bit all the time and at its worse also from cold. Iv just got a fuel filter today to fit..as iv been told that SHOULD cure it.!! Good Luck Jon |
17th Jan 2011 9:31pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I'm told it's the alarm disabling the engine. There is a kit, for £5.00, to by pass the engine cut out on the alarm. When mine does it the proceedure is: turn off, arm the alarm, unarm the alarm, open a door then shut it and it starts first time. Someone said it's because you are near a Wi-Fi point. Don't know about that one.
Merlin |
20th Feb 2011 6:21pm |
