Home > Puma (Tdci) > 110 Suspension |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Taken these direct from the Devon 4x4 website, So the rear is lifted by 2,1/4 inches and the front by roughly 1,1/2 inches. This lift will also depend on how much extra weight you have bolted on to the landy, for example a winch, roof rack, drawer unit, twin batteries, wheel carrier, Larger tyres and wheels etc. etc. will make the suspension lift nearer to a standard spring set-up on an unmodified defender not carrying anything extra. OME 751 Old Man Emu Coil springs for Land Rover. 390mm free height 230 lbf/in Suits :- Discovery 1 & Range Rover Classic diesel front upto 50kg over 30mm lift Defender 90 & 110 V8 front 51kg to 110kgs 40mm lift Defender 90 & 110 diesel front upto 50kg 30mm lift Defender 130 diesel front upto 50kg 20mm lift OME 755 Old Man Emu Coil spring for Land Rover 110 & 130 rear. 435mm free height 300 lbf/in Suits :- Defender 110 rear constant 300kg 55mm lift Defender 130 light load 25mm lift |
17th Jan 2011 2:47pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2394 |
I do not know about Devon but, ARB-OME figures are/were crap at the time I got the springs. I believe now they have new part numbers. Puma 110" SW
17th Jan 2011 3:04pm |
Yes you are right they do now have new part numbers They are now OME2751 and OME2755
17th Jan 2011 3:07pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Take a look here Oh and they have run out of Bali Blue. 130's have feeling's as well you know |
17th Jan 2011 6:04pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
I love that Landy Andy! (sorry, I am a poet and I don't know it) |
17th Jan 2011 6:25pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Out of interest, those of you with HD springs which are giving lift, do you have any suspension issues? ie are the bushes on both the front and rear radius arms true/square? particularly the rears where the front end joins the chassis?
17th Jan 2011 6:27pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
Doesnt the 90 Puma XS come with heavy Duty suspension as standard.
On My build sheet it has HD suspension on it...and i didnt pay for it Mike |
17th Jan 2011 6:33pm |
HD is definitely extra on an XS, mine doesnt have it. I fitted my own, apart from the secondary springs in the rear which were done by the infamous Ali Nassir. TC, if you get down on one knee and look at your rear radius arm, is it sitting true in the bush and housing? I'd be amazed if it is with +3"? |
17th Jan 2011 6:38pm |
Sorry Mike, dipped into the thread without reading through and got the wrong end of the stick. My springs give a 1.5 inch lift, the rest is in the wheels and tyres, overall height is 3inch - alignment is therefore obviously pefect.....will read further in future |
17th Jan 2011 8:15pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
If you have questions on springs/shocks my recommendation would be to talk to Chris Hill at Devon4x4 - he'll ask you what you want to do with your truck.
So for my set up as I will be going for a light winch - ie with Plasma not steel; simple clubman winch bumper - we ended up with a softer spring than if you want a lot of bull bars, bash plates and big-boy winch. For the rears I went with medium sprung for day to day use with medium weight and I bought a spare set of stiffer rear springs for when the truck is fully loaded up and going away somewhere - e.g. roof tent, rack, diesel, water, wheels, paraphenalia etc etc All above OME +2". Shocks +2" Koni Raid - indestructable (supposedly). Give Chris a ring - he's passionate about getting it right |
17th Jan 2011 9:55pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Gwyn Lewis is the set on my eyes.... standard height, OME Shocks and springs (and a few other bits):
Glyn |
17th Jan 2011 10:02pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
if the buget stretches take a look at the new D44 king suspension set up ?
its the mutts nuts and rides great steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
17th Jan 2011 10:16pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Had a look at mine standard 130 red&blue fronts purple with helpers rear.
17th Jan 2011 10:20pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
But the HD spring for the back are double coil aren't they ? As 130 ? The biggest weight I carry in tha back of my 110DC is my 60kg dog ! Do I really need to fit the HD in the back ? I'll be fitting the HD in the front, next week ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
18th Jan 2011 12:00am |
