Home > Td5 > Defender 90, Rear Drawer System
christyler
I wanted to fit a drawer system to the back of the 90. I look around at what was avalable and although the ones avalable were very good quality the prices were staggering.
So i set about making one myself, eventually the load space will be covered with a treadplate arrangement that will lift on electric rams, so all i really need is some where to put jack, jump leads,toe ropes etc so that the rest of the space is left for her indoors to fill with shopping, clothes and shoes.
I also incorperated a 350amp jump lead connector and a 12volt outlet for good measure.
I started by fabricating a 18mm wpb base to make it sturdy, i am not a carpenter but i can just about screw a few straight bits of wood together ! i made the drawer from 13mm wpb and fitted a ally frame into the front to rivit on the treadplate door, then two more bits of treadplate either side of the door to match it up.
The 24" door slides came from b&q, i painted all the wood both sides with primer first then black. the top of everything is 18mm wpb, this will be the new floor level in the rear loadspace, i sealed all around the edges of the ply with black silicone, i will probably cover the top with some black carpet.
I used stainless steel screws and self tappers throuout.
Pictures in Gallery
Post #53391 17th Jan 2011 2:25am
AndrewS
Nice one Chris Thumbs Up I do have one question though. Was the yellow square of any use bearing in mind that you were working on a land rover.
 130's have feeling's as well you know Smile
Post #53396 17th Jan 2011 7:24am
christyler
Square
Andrew, Actually no ! I made the base first "square" then when it came to fitting i had to adust it about 10mm.
fitting that new rear bumper was a laugh as well "it just lines up with the existing chassis holes" !!!!!!!
You have to love LR
Post #53411 17th Jan 2011 10:35am
TACK
Nice work Chris Thumbs Up
Post #53422 17th Jan 2011 12:40pm
BigRuss
I could ask a similar question as Andrew with regards to that spirit level? Rolling with laughter Russell
2011MY 110 XS USW Black
Post #53439 17th Jan 2011 1:53pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Very nice work! Thumbs Up
I'm still drawing my drawer and I'm collecting the material.
Where did you find the handle you used?? Matteo
Defender 110 Td4 SE MY 09
Post #53443 17th Jan 2011 2:24pm
landydubai
United Arab Emirates 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Excellent job Thumbs Up LandyDubai
Keep the shiny side up!
09 110 XS BAS remap
09 90 pick up BAS remap
08 D3 V8 G4 Spec
Bentley Speed GT 2009
G55 2003
Ford Raptor 2010 - new toy!
Post #53449 17th Jan 2011 3:19pm
christyler
Thanks
Thanks guys, it's a work in progress, sadly i only get to work on it at the weekends. She brings it to work during the day.
Bomber82, got the handel from a local supplier, there is a great place in the UK for that sort of stuff http://www.whb.org.uk/acatalog/Locks___Handles.html I found them after i had already paid twice the price for mine, you live and learn.
Post #53564 18th Jan 2011 2:19am
Bomber82
Thanks Christyler!! Thumbs Up
I'm looking here in Italy but it's very difficult to find out....at the end I will ask to whb if they ship abroad.. Matteo
Post #54867 24th Jan 2011 8:04pm
